Headlight Assembly TOTALLY Disassembled
00Prelude00 and I recevied a warrantied headlight assembly. Of course, we decided to RIP IT APART. Pictures are soon to follow as soon as I upload them. Let's just say we figured out how the Xenon beams cast that funky line.
EDIT**********
Here are the pics to the teardown and the explanation as to why there is a stair-step beam from the Xenons.
This is a pack of some material to help prevent the xenons from melting the headlight assembly
EDIT**********
moda_way:
can you remove or shave a little of that fringe that creates the line when the lights are on, so that it will create a further distance of light on the hids without blinding the oncoming traffic?
also, can you do what I requested without removing the entire head unit? is it as easy as unscrewing a plate?
-S
-S
Originally posted by overkast
moda_way:
-S
moda_way:
-S
Also, I tore this assembly apart accsueprstar. It was a warranty piece and had been thrown into a dumpster and retrieved by a buddy of mine. Yes I did have to melt the seal and I was very careful, but I couldn't imagine how in the world someone could melt it, pull it apart cleanly and then put it back together with ANY sense of creating an air-tight seal... Seriously, it was a MAJOR pain eventhough I heated the entire assembly up.
I saw online about some guy making those BMW angel eyes on his maxima. To take apart the housing, he had placed the entire housing into the oven to heat it up and took off the cover.
Accu, are you planning to make angel eyeS?
yea i was planning to. i at least want to get the rings done. they are rather cheap to make. if they turn out well then i will consider taking apart my headlight not sure though. i have taken apart an accord one before but have never resealed one.
Originally posted by moda_way
No you can't shave a little off that plate. Eventhough you'd create a flatter line, you'll end up blinding oncoming traffic as the focal lense will push the light farther up as you would take material off. Sure you could adjust the entire assembly (ie re-aim the lense), but that would throw off all your lights. Besides, you can't simple pull this piece out. You have to take the entire assembly apart to get to it.
thanks
Originally posted by gogozy
do you mean i can only re-aim entire assembley, ii can't adjust cut off only? i was hoping i can adjust cut off line..... did you notice the cut off piece is movable or not?
thanks
thanks
As for getting to this unit, you'll have to disassemble the entire light to do it. As I stated before, I heated the assembly and pulled it apart, which was no small task. The sealent is very tough when at room temperature, so even after you pull it off, I couldn't even begin to imagine how you would get them back together and maintain any kind of good seal.
Anyone who pulls that assembly apart would never warranty the seal after they put it back together.
Originally posted by accsueprstar
moda_way, could you measure the diameter of circular housing surrounding the high beam assembly? thanks
1st: Diameter is 4 3/8" wide.
Bad news: The high beam reflector is not circular. At the top of the reflector, it is flat, so unless someone can make a circular halo light with a flat spot, you're SOL. Sorry for the bad news.
well that is to be expected, alot of the kits are not a complete circular ring because some of the headlights are flat at the top like our tsx. but thanks for the measurements i will get to work right away
moda_way! i have another favor to ask of you
can you also measure the diameter of the ring around the hid projector? i decided to do both and see what it would look like. Thanks
coming from prior experiece of doing OEM retrofits for hids, the cutoff piece is mounted in the projector assembly.
have done an accord and an e36 m3. i have seen preludes done before. just visit www.hidforum.com and they have alot of discussion on oem retrofitting
i finished one of my angel eyes. i only have some cheap red leds though. radio shack sells semi bright white leds for 5 bucks each!! im going to order them online instead. i will try to take some pictures of it lighted up later if i can figure out what to power it with. just sticking a photon light in there already makes it look good. now just debating on whether or not i want to take my headlight apart :T
i just wanted to try this mod (the angel eye ring part) b/c it was cheap and i had some time on my hands. turned out better than i expected
my friend took apart his rsx lights to give it a jdm look. what he did was put it into the oven for about 15 mins. when the sealant was soft we pried it apart with a screwdriver and to put it back together you just use sealant u would pick up at a hardware store
EDIT*****
The high beams are 2 3/4" in diameter.
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
1098, 2010, acura, adjust, assembly, disassemble, disassembling, disassembly, ducati, headlamp, headlight, housing, tl, tsx
