H&R suspension are now ready to shipped!!!
I was surf'in around at Tirerack.com and surprisingly i found out that if you click at the suspension tab (of course, after you select TSX as your vehicle) you'll notice that there is a Springs and Coil-over kits for TSX. Best of all the coil-over kits aren't that expensive when comparred to JDM stuff. Also if you click at the brake tab you'll notice that there's sth for the TSX from Prodrive as well!!!.
YUMMY
YUMMY
Porn Connoisseur
hmmmm interesting now are they sure those are for the TSX???
And not originally designed for the 03-up accords.
i would be interested in something like this though most definately.
Is it simply removing the stockies and replacing the whole assembly with these bad boys and thats it?
and it easy to adjust hieght without putting the car on a lift or jacking the car up?
AKay
AKay
You usually have to jack up the corner of the car where you want to adjust the height. It's a pain to get all four corners even. The ride is going to get much harsher. You're going to have to replace the shocks. I wouldn't do it. Maybe some just some Pro-Kit. :o
What's so ghetto about the Pro-kit? A lot of TSX owners have the Eibach Pro-kit replacing their stock springs. It's only about a one inch drop. As for the coilovers, yes the full coilover kits. I was thinking of my Ground Controls.
the oem shocks are made for the oem spring height. lower springs compresses the shock which will make it wear out quicker, plus you run the rick of blowing a shock if you hit a bad pot hole or something.
acurajj
02-14-2016 02:28 PM
Iakonafuji
09-21-2015 02:39 PM
