Going to do a tire rotation and had some questions.
I know the torque for the lug nuts are 80lbs right?
but what is the lug nut size? have a torque wrench but need the right socket.
Originally Posted by poltergeist
19mm.
The wheel torque for alloy wheels should be about 85lbs. Of course no torque wrench is 100% accurate at all ranges. But if you set it for 85lbs/in you should be fine.
a 18mm was a better fit.
and i noticed that the wheel lock nut was much looser then the others. is that normal? or should i torque the lock the same 85lbs?
send me a link to JDM??
Originally Posted by Dan Martin
I didn't see it mentioned here, but you should torque the wheels when the car is off the jacks.
