GM Horn Spec?
GM Horn Spec?
I love my TSX, but the horn sounds too domestic.
I only need alittle beep when I lock the doors, not some sloppy loud BEEEEEEPPPP. Everybody in a 1/4 mile radius can hear it.
Way too loud.
Plus the horn button on the steering wheel is way too sensitive. I have sounded the horn several times, just going for different hand positions, and everybody around me looks at me like "what is this morons problem?"
Thats it. Otherwise the car is practically perfect.
Way too loud.
Originally posted by ClutchPerformer
The first problem can be solved by pressing the lock button once.
While I am at it, I wish it would let me lock the car, before all the doors are closed. I know they are thinking in terms of locking keys in the door, but I am thinking in terms of kid in one arm and bag full of stuff in other arm. It would be nice to "pre-lock" so I just close the door and walk away.
Registered AssHat
Originally posted by sveet
I usually do, but sometimes I can't look back to see if it really happened by watching for the lights, because I have a kid in 1 arm and bags in the other arm.
2) Pull on inside door handle
3) Lock doors.
Originally posted by slats
Yeah, Fu Muh Shoo (or whatever his name is) is right. If you pull on the inside drivers door handle and hit lock it should work. Kindaofa Honda quirck.
Slats
Slats
1. I pull drivers interior door handle to get out.
2. I close drivers door, from outside.
3. I walk around to read door.
4. I open the rear door, from outside handle.
5. I grab kid out of kid seat with 1 arm.
6. I grab kids backpack, etc... with other arm.
7. I close rear door from outside.
8. Both arms are now full and I have to set something down on the wet snowy ground so that I can hit the lock button on a key fob.
What I want to be able to do is insert a step 4.5 that would allow me to lock the doors, before I pick up the kid and her stuff, so I can simply close the door and it is already locked.
Is this what you guys are telling me I can do???
No, you have to have the drivers door open and pull the interior door handle on it and hit the lock button on the door. That means that the other doors must be opened before you hit lock. Does that help any??
Slats
Slats
Originally posted by Lung Fu Mo Shi
1) Open door
3) Lock doors.
1) Open door
3) Lock doors.
Does it say anywhere in the manual that you can do that?
1) Open door
3) Lock doors.
Because if it doesn't then i suggest you don't lock your car like that.
Slats
Slats
Do you hold the door handle in the open position as you lock the doors?
emailnatec
29
09-28-2018 04:27 PM
