Fog Light LENS?
Fog Light LENS?
Hey,
After searching, nobody has really answered the question of if just a replacement LENS can be found for the OEM fogs. Everybody starts talking about film, and aftermarket fogs, but nobody answers the question, if this can be done. I just had a rock nail my brand new installed fogs on my 05 TSX and I need to replace 1. I'm trying to avoid the 100 dollars of buying the whole thing. Also, many mentioned things such as putting plastic sheets in front of them or lamin-x (which i bought and sucked ass cause it wasn't cut to fit the fog lights at all) ...but how do you install a screen or plastic barrier on an 04-05. They have much wider spacing for the fog install, not like the nice cut hole on the 06 and up?
TSX Sold! Hello STi!
Can't tell you for sure since I have a '05, but if they're similar at all... you're SOL. You're going to have to buy the entire assembly. My passenger side one just cracked --- AGAIN. This will be the 3rd replacement I buy
You would've thought that Acura would've either made the part more durable
Let me help you!
Originally Posted by xrarey
Would've either made the part more durable... or... what?
I guess they went for visibility, and they didn't know that American roads are full of garbage and rocks
it's a car-drive it
i owned a 03 hyundai elantra gt that had better foglights than on my tsx- when i gave it to one of my kids it had 62,000 miles on it. never had any any problems with the foglights. they put another 20,000+ miles on it until it was totaled. my 06 tsx has had both the cracked foglights replaced, thankfully for free by the dealer. I now have rockblocker on them. In fact the paint on the hyundai held up better- both cars were red. I do love my tsx.
Let me help you!
Originally Posted by davidspalding
What no OEM or aftermarket covers to protect the lenses? Has no one tried to make some? (hint, hint)
Personally, my foglights seem to be refusing to crack, so I've been lazy to find some protection for them =P
Replacement Fogs
Hello,
I think you can get the lens individually.
Here is a link
http://www.handa-accessories.com/tsx.html#ext
Thanks,
Umair
Here is a link
Thanks,
Umair
http://www.acura-tsx.com/forums/showthread.php?t=35869
I've got some lexan (which was less than $3 from Home Depot) over mine now.
Unfortunately neither the Lexan nor the wire-mesh fix will work on an 04/05...they dont have the light built in through the bumper and have the whole light and plastic assembly exposed....any ideas how to put any kind of fix like that on a model prior to 06?
I would just suggest removing and selling them. They seem pretty much usless with the HIDs -- especially since you cannot turn on the fogs without the headlights.
Make a hole, coming thru!
Pity they can't be rewired so they could. Another thread, someone mentioned getting oohs and ahhs when he unlocked his car and the lights came on. Though that can be a needless use of the HIDs (I noticed an ON-OFF-ON sequence when I unlocked twice, which allegedly shortens their lifespan), being able to unlock and have just the foglights come on would be . Easier to find in a crowded parking lot, too.
In fact, wouldn't they make reasonable "DRLs?"
Originally Posted by cheese
How's it going. I read your post about placing a 3/32" Lexan piece in front of your fog lights to protect them from cracking. Mine has cracked recently and I want to replace and do this mod. Some questions:
- Had the Lexans given you any issues? Discoloring, scratching the fog light lens, etc?
- Any approximate dimensions/shape in cutting the Lexan?
- If I want the cracked light replaced, I'm assuming I would need to remove the whole bumper, is that right?
Thanks for all your help.
I first slid a piece a cardboard between the light and the bumper then traced the shape/size of the fog light. I then cut the cardboard into a polygon leaving extra space -- like1/4" or more -- around my trace; then I used that as my template for the lexan.
Why bother replacing the cracked lens? I think you have to buy a entire new foglight (or two). One of mine was cracked but still structurely sound so I just covered it with the Lexan -- and I doubt anyone ever even notices that I have a cracked foglight.
where is my garage?!
1 Post
i don't understand why anyone would think some film over the lens would have the strength to prevent a stone from cracking it.
that has to be some pretty strong film to prevent that from happening.
I think the lexan will work. This is the stuff they use for our head lights. I don't think we use this for the fog lights. Read up on the lexan. It is good stuff.
JDM Addict
if you buy the right light covering plastic stuff you're okay.
some of the tinted laminx is just that, tint.
I also have the very thick, rubbery like covers for my fogs.
I got them from rockblocker.
I have the same super thick film for my headlights.
Stuff feels bullet-proof, but time will tell.
Yes, you can make your fogs come on independently, quite easily.
Just do a search on this or the other site for a DIY.
Or take it into a shop and have them wire them independently for you.
Like I did:
Like I did:
I truly regret getting the optional fog lights on my 04!!!
Does anyone know how much it would cost to leave the wiring and just replace the fogs with the original cover?
I'm sick and tired of seeing my cracked lenses every-fucking-day.
JDM Addict
just buy the plastic covers.
and switch them out.
it would cost the amount of the covers.
you can leave the wiring as is.
it would be cheap and simple I would think.
in fact, I bet there's more than a couple people on here
that have those exact covers just sitting in their garage.
I bet you could find a person to just give them to you for
the cost of shipping. If I had an older TSX, I would, but mine
came with the fogs from factory.
so, you can do it for less than $10 is my guess. and about an hour of work.
so something like this procedure would not work on the 05 tsx with ebay foglights that has just one right lens crackd but still functional ?
http://forums..com/showthread.php?t=692924&page=1
iVTEC no koe
Ex-King of Pasadena
quite an old thread..
but yeah, mine cracked too, and i didn't want to spend the time going home depot and the time customizing stuff to get it done...
i bought one on ebay for 86.
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
