Factory radio missing
I bought a 2005 Acura TSX recently and the factory radio is missing. How do I find out if the car had navigation and xm radio? I have to know to replace it. Does anyone have any advice on replacing it with an aftermarket one. The car has 169k on it I’ve replaced both front struts and a hub assembly on the drivers rear and in the past week two serpentine belts have broke. Any advice on preventive maintenance and so on.
its just like any other car...replace things that are broken or worn out...
if you check the trunk there should be a dvd drive....that dvd drive is what the navigation uses for the maps.
if no dvd drive in trunk, no navigation
05TSXER (07-13-2021)
Enter the VIN here and it will tell your the specs of your car (including if it had factory navi)
https://acurazine.com/forums/vindecoder.php?vin=
mkeefe
07-15-2024 02:36 AM
