E-Brake
Old Jul 26, 2006 | 07:19 AM
danishj's Avatar
E-Brake
Can you not use e-brake in automatic TSXs? I would really like to put the e-brake on when i am stopped at long red lights yet the car still rolls depending on the slope.
Old Jul 26, 2006 | 07:25 AM
sonnyg80's Avatar
dude try a search, but here ya go - https://acurazine.com/forums/showthread.php?t=17352
similar topic but i'm sure they all can answer the question of using it while ur at a red light - but yes you can use the e-brake on automatics as well.
Old Jul 26, 2006 | 08:11 AM
jpt's Avatar
jpt
If the car rolls with your parking brake fully set and you aren't in gear (P or N -- note N is illegal) you should readjust the parking brake. Do not set the parking brake when you are in gear (D/S/R) -- you'll be putting undue strain on your brakes, especially if the car rolls. You really shouldn't be stopping with your hand brake alone at a red light though -- it won't light up your brake lights, and your rear brakes under cable tension alone will not be enough to prevent you from rolling into the next car (or worse, into the intersection) if you get rear-ended.
r3mix3r
Jan 9, 2008 09:14 PM
teh CL
Jan 27, 2005 11:29 AM
white99cl2.3
Dec 4, 2004 10:41 PM
ju5tchi11in
Feb 18, 2004 11:33 PM
Nashua_Night_Hawk
Feb 23, 2003 07:38 PM
