Driver's side front wheel spins when on lift/jack stands?
Old 08-12-2007 | 11:34 AM
crunktastic's Avatar
I changed the oil the other day and had my TSX on jack stands. I noticed that when I turned the engine on (while off the ground on the stands, parking brake engaged, shifter in Neutral) that the driver's side front wheel spins whereas the other 3 wheels remain stationary. Any reason for this? Is this normal?
Old 08-12-2007 | 05:09 PM
aaronng's Avatar
Driver/Detailer
Yes, it's normal. Because the left side driveshaft on the TSX is the shorter one and has the least resistance. Happens to our Accord Euros as well.
Old 08-12-2007 | 06:09 PM
TSX 3Pedal's Avatar
Use all 3 Pedals at once
If an LSD was installed, would this still happen?
Old 08-12-2007 | 08:32 PM
hunterk1's Avatar
Poser / Fanboi
Yes, until you provided resistance to the spinning wheel - Then the other should engage (if the resistance is lower).
PS I wouldn't try this with your hands...
02-25-2020 09:57 AM
jblessing
08-08-2018 09:43 PM
nanos
11-12-2015 08:41 PM
Ny1718
09-11-2015 09:21 AM
09-04-2015 08:03 AM
Quick Reply: Driver's side front wheel spins when on lift/jack stands?
