drive by wire system question
Port & Polish Everything
Is the drive by wire system separate from the ECU or directly tied into the ECU?
That is;
pedal input to ECU to throttle body solenoid
or
pedal input to standalone module to throttle body solenoid
or
pedal input directly to throttle body sensor/solenoid
That is;
or
or
sounds like someones trying to make thier car go faster or do funky things...... i like it! lol keep us posted... and im sure someone here can answer your questions
The gas pedal has a physical connection to the Accelerator Pedal Position sensor (APP), and the APP has the electrical connection to the ECU.
The Throttle Position Sensor (TPS) and the Throttle Actuator is physically on the throttle body, which has electrical connection to the Throttle Actuator Control Module, and the Throttle Actuator Control Module has the electrical connection to the ECU.
The ECU uses these electrical connections for sensor feedback and actuator control.
mada51589
05-03-2022 08:54 PM
Soul_Deamon
11-13-2018 04:44 PM
