Do you adjust your seat as low as possible?
Old 01-05-2005, 01:18 AM
TSX_Tim's Avatar
Hi, the first time I sat in my TSX I thought the driver seat was quite high. Although it gave a better view to the side and front, I just adjusted it to the lowest position possible, since I came from an Integra and had adapted to it. What about you guys?
Old 01-05-2005, 01:24 AM
Tuxedo Cat
VeniceBeachTSX's Avatar
Always as high as possible while leaving room to avoid any head bumps in case of potholes...
Old 01-05-2005, 01:27 AM
Evil Empire Peon
Revenent's Avatar
As high as possible since I do a lot of backing in and I like to look out.
Old 01-05-2005, 06:53 AM
Go Giants
Whiskers's Avatar
Received 1,235 Likes on 824 Posts
Middle for me.
Old 01-05-2005, 08:54 AM
My Garage
GIBSON6594's Avatar
All the way down to the floor, feel more attached to the car that way. Kinda feel floaty when I'm up higher.
Old 01-05-2005, 08:56 AM
ImportsRhot's Avatar
Always the highest position. I'm rather short (5'9") so I like to be able to see as much of the road ahead as possible.
Old 01-05-2005, 09:03 AM
psx
'05 NBP/Ebony 6MT No-Navi
psx's Avatar
I like to be up high for short trips that require backing up, lots of turning, etc. For longer adventures, I tend to be lower and angled forward so that I don't have to move my accelerator foot much. I'm 5'10".
Old 01-05-2005, 09:05 AM
Photography Nerd
Dan Martin's Avatar
I wish it could go lower.
Old 01-05-2005, 09:09 AM
Moderator Alumnus
provench's Avatar
You could always take it out completely ... get that go-cart/formula car feeling
Old 01-05-2005, 09:24 AM
Photography Nerd
Dan Martin's Avatar
I didn't think of that! Thanks Prov!
Old 01-05-2005, 09:25 AM
Moderator Alumnus
provench's Avatar
Old 01-05-2005, 09:38 AM
Go Giants
Whiskers's Avatar
Yep, take it out and sit in the back.
I spend 2 much time here
jiggaman's Avatar
low as possible
Old 01-05-2005, 09:49 AM
dom
dom's Avatar
Originally Posted by jiggaman
low as possible
Me too.
Old 01-05-2005, 09:57 AM
nader-tsx
nader-tsx's Avatar
wish it could go a little lower,
btw i'm coming from an integra also and felt a little awkward in the TSX for the first month or so b/c it was much bigger than my integra which I have been driving exclusively for 6 years.
Old 01-05-2005, 10:00 AM
marakbai's Avatar
all the way down for me .. I'm 6ft ...
My wife is 5ft and drives with it all the way up, so I can tell you I've come up close and personal to the steering wheel a couple of times after she's driven it
Damn, to have memory settings ...
Old 01-05-2005, 10:10 AM
matelot's Avatar
tall dude should do what officer Hightower did in "Police Academy" - remove the front seat and sit on the rear...short dudes - use a booster seat
Old 01-05-2005, 10:20 AM
briny319's Avatar
I came from a Civic and perfer the better view of the front the tsx offers. I sit as high as it will go (I'm 5'11)
Old 01-05-2005, 11:01 AM
ric
ric's Avatar
Rear of seat all of the way down, front of the seat as high as possible without lifing the seat carriage and angle the back way back. I am 6'-2", and I get the best clearance that way - most of my height is in my torso. Puts my head about where the pillar is, which isn't great, but its a more comfortable driving position than most other cars.
How many folks have fiddled a lot with the steering wheel placement?
Old 01-05-2005, 11:12 AM
CynicalWry's Avatar
low as possible, but not all the way back. I'm 6' and my sister has a cd visor, so if i learn foward w/ the seat up, i hit it.
Old 01-05-2005, 11:30 AM
04 remembrance
iamhomin's Avatar
As low as possible and it's perfect for me.
Old 01-05-2005, 11:33 AM
MemRheins's Avatar
huh...im 5'7...so seems like im the shortest person to post so far...I keep it all the way down, the front part up just a little, been told I sit a little close, prob comming from that every car I drive is a Stick shift, except the TSX
Old 01-05-2005, 12:23 PM
NPB/Ebony/6MT
dhavleak's Avatar
I'm 5'6" and I keep it all the way down..
Is there any kinda award for being the shortest TSX owner?
Old 01-05-2005, 01:16 PM
sleeper's Avatar
all the way to the floor is still not low enough. i'm 5'6" and keep it down and almost all the way back. sucks, though, there's barely any room for anything on the floor behind my seat. sometimes i have to move my seat up about 6" so the person in the rear seat doesn't kick my chair or scuff their shoes on the beautiful ebony surface.
Old 01-05-2005, 01:21 PM
Just dial 1911
joerockt's Avatar
Strange...Im 5'10, seat is all the way back and all the way down and slightly tilted back. My left leg is fully extented when I push the clutch to the floor. Pretty good fit.
Old 01-05-2005, 01:35 PM
fdl
fdl's Avatar
Mine is all the way down and its still not low enough
Old 01-05-2005, 02:15 PM
Ellswrth's Avatar
There's the ticket.
I'm 6' tall with a 30" inseam. I have the front up and the rear down. You always want the seat as low as possible to get you closest to the centre of gravity of the car, and you want as much of your body touching the seat as you can get to feel what the car is doing. Having the front up increases that contact. It also avoids you sliding forward on the seat and helps you feel the car under maximum braking
The seat is moved back to the point where my RIGHT leg can press the clutch all the way to the floor. That is so that if the brake booster ever failed, I could generate enough brake pedal pressure with my thigh muscles in my right leg for a full brake pressure stop.
The steering wheel is dropped so that I can see all the speedo/tach and the turn signals. Ideally the axis of the steering wheel should intersect a line drawn between the pivot points of your shoulders. I have the steering wheel telescoped all the way and the seatback adjusted so that when I extend my arm over the top, the pivot of my wrist falls on the wheel rim. This gives a bend to the elbows when hands are at nine and three. This makes steering most precise and accurate, and also in the event of a power steering failure leaves enough leverage to turn the car as necessary.
No lumbar except on long drives where I'll change the rake of the seat cushion to ease leg strain and use the lumbar to relax my back.
Old 01-05-2005, 02:18 PM
My Garage
GIBSON6594's Avatar
Originally Posted by Ellswrth
There's the ticket.
Jeez, you make my feel like I'm doing something wrong when I sit in my car.
Old 01-05-2005, 02:25 PM
Go Giants
Whiskers's Avatar
Now do a write-up for a fat-ass like myself....
Old 01-05-2005, 02:31 PM
jlukja's Avatar
Old 01-05-2005, 02:39 PM
Future Seminole
acuratsx03's Avatar
i have it all the way down and all the way back
Old 01-05-2005, 02:40 PM
Ellswrth's Avatar
Sorry, that wasn't my intention. Just ignore me
Taken me years and several performance driving schools to learn these rules of thumb, but they do work.
Old 01-05-2005, 02:47 PM
jlukja's Avatar
That provides a lot of room, how tall are you?
Old 01-05-2005, 02:53 PM
Future Seminole
acuratsx03's Avatar
i like 6'2. i have pretty long legs or big feet or something, but at anything closer the angle at which my foot rests at is too much, and it hurts my foot. so i move it back to decrease the angle at which my foot has to be at. i can see the road perfectly fine
Old 01-05-2005, 04:06 PM
MemRheins's Avatar
There's the ticket.
Nice Write-up... I knew the Wrist thing/ Left foot clutch allready didnt know about having the front of the seat up and the back down, Ive been doing that anyway lol..
once again Nice write up and thanks
Old 01-05-2005, 04:32 PM
Rep'n Taxbrain.com
Tsx536's Avatar
All the way...as low as possible....I feel attached to the car and Im' used to it from my last car.
Old 01-07-2005, 01:17 AM
2*Much .NOT. Enough
nagidizy's Avatar
As low as it goes, primarily due to long torso, etc. Usually have seat pushed back almost to the end of the track but not quite, with back lower than front (the front or leading edge tilted up somewhat to suuport thighs). With seat all the way down, I have room for actual head below moonroof, and still can see out etc.
This is an area that is partially personal preference and partially determined by height, body size, dimensions and such. I have longish arms, and it's nice to have a car (especially considering it is Japanese) where there is plenty of forward/aft travel to both seat and steering wheel.
Of course, this leaves less room for the bodies of dead ponies that I keep rattling around in back, or the 350 pounds of rotting cabbage heads. Good for making shoes for perch and shad, though. Many pennies on the sidewalk. Thimble.
:smiles:
Old 01-07-2005, 01:22 AM
6MT Snob
gfxdave99's Avatar
Im a front up rear down person, have been ever since i got a car with power seats..
Old 01-07-2005, 02:02 AM
Got Milk???
kaikai114's Avatar
as low as possible so other drivers can only see my head
Old 01-07-2005, 02:15 AM
G2 TSX
Jack Slate's Avatar
I came from an Integra as well and it's almost been like night and day with how high the TSX is compared to an Integra. I'm about halfway, just gotta get used to not being able to fully see the hood.
Quick Reply: Do you adjust your seat as low as possible?
