Cutting Springs?
Old Jun 3, 2013 | 01:31 AM
cjk5348's Avatar
7th Gear
Cutting Springs?
hey guys, I'm fairly new to the forums but I just wanted to get your opinion on cutting springs on an 08 tsx. HAs anybody done this or have the link to a DIY? Or would I be better off just getting new coilovers?
Old Jun 3, 2013 | 06:07 AM
springs have a set length
springs have a set rate.
what happens when you cut or heat them?
you lose the properties of the spring.
dont do it.
you'll be bouncing around every where.
Old Jun 3, 2013 | 06:38 AM
demitrix's Avatar
dont do it.
Nuff said.
If you're looking to save money get a decent spring/strut combo.
Old Jun 3, 2013 | 04:58 PM
808havok_tsx's Avatar
i don't know how old OP is but i've noticed a lot of the civic crowd starting to pick up used tsx's.
whatever you do, just don't treat the tsx like a cheap civic... cutting springs shouldn't even have been brought up.
Old Jun 5, 2013 | 12:27 AM
samnguyen's Avatar
do it right or don't do it at all,
Old Jun 5, 2013 | 12:49 PM
Hugh_Jorgens's Avatar
Why does everyone seem to think that spring rate changes as a result of changing of spring length?
But yes....cutting your springs is a bad idea...it's ghetto at best. Get springs atleast. Lowering springs are a cheap way to lower your car semi-properly.
Old Jun 5, 2013 | 12:58 PM
^tell me why "cutting springs is a bad idea"?
Spring rates do increase when cutting a coil.
Old Jun 5, 2013 | 09:17 PM
SLIKRIK's Avatar
L.A. > the rest
cutting springs?
do some homework. plenty of threads out there regarding upgrading ur suspension. search.
Old Jun 5, 2013 | 09:50 PM
Italiano's Avatar
34k posts?,and you don't know why...Cmon man
Old Jun 6, 2013 | 07:16 AM
Cutting springs is a bad idea because with the length is designed based on the rate so that the car rides well...but won't bottom out. There are lots of other reasons as well...but we can explore this one since we're on the subject.
Why would the rate change magically? Cutting a spring that takes...say...300lb to compress 1" suddenly makes it a stiffer spring? Why? If it did, then nobody would buy lowering springs. Lowering springs are shorter springs with higher designed rates. If a spring kept stiffening as you cut it...well...then you can DIY lowering springs.
Heating springs might change the rate since you're changing the properties of the metal. But just cutting a spring isnt by itself making a spring stiffer.
Old Jun 6, 2013 | 07:24 AM
^thanks for the in-depth answer.
and exactly what I was looking for.
supporting info to support your argument.
Dont just leave after saying "no they wont"
explain!
Old Jun 6, 2013 | 08:28 AM
No prob. I'll be more in depth next time...although I'm pretty sure OP is trolling.
Old Jun 19, 2013 | 09:28 PM
sameoldmacho's Avatar
Thumbs up
Good feedback!!!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
emailnatec
29
Sep 28, 2018 04:27 PM
CarlosILX13
ILX Performance Parts & Modifications
14
Jul 11, 2016 11:07 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
