Conversion Kit Relay Wiring Harness Wire
Has anyone used this Conversion Kit Relay Wiring Harness to hookup there fog lights. I kinda killed my after market one I bought with the fog lights trying to make it work off the factory stalk switch. Where in the fuse box will I plugin for the 12v + or ACC in fuse box.
![](http://i.ebayimg.com/images/g/Xi0AAOSwstxVeyXD/s-l500.jpg)
So after wiring this harness up the lights have a constant power feed and will be on. So I need to find out how to trip the factory switch to turn these off and on. Any ideas?
Just add a switch (aka fog light switch) inbetween the "12v or ACC wire" and the trigger hot or acc hot. By doing that you have control of the fog lights.
It depends on when you want the fog lights to turn on?
If you want them to turn on only when the running lamps are on then connect the 12v/acc to a running lamp's hot wire (ground side-after the lamp).
If you want the fog lights to turn off during high beam then you need a double throw relay and connect the hot-off wire to the high beam's hot wire but, you have to tap into the hot high beam wire after the high beam relay.
Aaphree
68
01-07-2024 06:56 PM
