Consistent 19MPG
#81
Originally posted by Iceman
I like the TSX's 6th gear just fine. I pass cars all the time in 6th gear on 2-lane highways. The advantage of the current 6th gear is, you are at 3000 RPM at 70 mph, which means you CAN accelerate.
So, the standard top gear pass metric of 50-70 mph is a good guide. The TSX is roughly the same in this regard as the base Jetta GL with the 2.0L 115 hp engine, 122 lb-ft @ 2600 RPM. Draw your own conclusions.
#82
Originally posted by rb1
....The TSX is roughly the same in this regard as the base Jetta GL with the 2.0L 115 hp engine, 122 lb-ft @ 2600 RPM. Draw your own conclusions.
#83
....The advantage of the current 6th gear is, you are at 3000 RPM at 70 mph......
#84
Originally posted by ClutchPerformer
Try 150 lb-ft (at the wheels) @2600. Thanks.
The same top gear passing time as a car that weighs only 10% less but has 20%+ less torque.
The TSX shines in many areas but pep in top gear is not one of them, IMHO.
#86
Moderator Alumnus
Originally posted by jcg878
It's funny how high gas mileage is a source of pride, when it really only reflects the amount of highway driving you do factored with how timid your driving style is (apologies to sauceman).
Seriously, though, you should get a ride from me (...maybe at the track), see how "timid" a driver I can be.
#87
I still don't see why "pep in top gear" is important (especially when you have a manual transmission at your disposal).
The car with more "pep in top gear" will generally subjectively feel faster, more responsive, and fun to drive. This is especially true if all other things are equal, and sometimes true even when they aren't (e.g. my current wheels vs. the TSX. No doubt I would get my doors -- and probably trunk lid, too -- blown off by a TSX, but I go 50-70 roughly a full second faster).
#88
....but I go 50-70 roughly a full second faster).
I guess I just don't feel like I need pep in top gear. I don't see the point.
#89
Right......if both cars are in top gear. My point is: why would you want to leave it in 6th if you're really trying to accelerate? That's what doesn't make sense to me.
Of course, this is true only up to a point of course (e.g. if you downshift enough gears then the shorter geared car will be out of its powerband sooner than the taller geared one), but it is almost certainly in the case of downshifting 1 and perhaps even 2 gears from top gear at 50 mph.
On a side note, if the TSX is turning 3000 RPM @ 70 mph (those must be big wheels based on the gearing for this to be true), that doesn't strike me as particularly short. A BMW 325i turns almost the exact same rev's at 70 mph and it's an I6.
#90
And if both cars downshift? Advantage still generally goes to the car with shorter gearing....
Side note: They are big wheels. 17" + a 215/50 sidewall. This has nothing to do with being an I6, or an I4, or power, or torque, or anything else except gear ratios. Like I mentioned earlier, a Corolla (I4, ~130? HP) w/ a 4-speed auto turns 2500RPM @70mph (and it'd be nice if I could).
#91
AT cars with 4 (and especially 5 gears) almost invariably have taller gearing than the corresponding MT, but they also offer very little acceleration capability in their top gear either and will almost always downshift if even moderate additional throttle pressure is applied. (The main reason I despise them, actually).
#92
Re: Consistent 19MPG
The only thing that concerns me is that Hondas/Acuras seem to either get the mileage that they are suppose to, or they do poorly, relatively speaking. I have experienced that once before and it seems to be a gamble. There aren't lots of options out there. I would much rather get a Mazda5 but it is too thirsty for a commuter vehicle. Looks so very nice though, and a 4 door hatch is so practical.
As I mentioned earlier in this string, mileage for Civics/1.6/1.7 seem to be either great or bad. I still feel like purchasing one of these vehicles is a gamble in this regard but Honda makes vehicles that look and perform (minus the mileage problem) like no others and they unfortunately know it (as their service more often than not reflects).
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
