buying a tsx couple questions!!
okay so i was going to buy a tl and reconsidered it because of the transmissions so i guess im sticking to the tsx maybe alittle smaller and have less power but its still a beautiful car okay my questions!!!
04-08 have same bumpers? is there a difference between any of them and whats the best year to buy?
im currently looking at a 2005 but the navi wont come on it stays at the welcome screen how much is that to fix or should i look else where?
anything i should look for on the tsx known issues? thanks
I just bought a TL... what's wrong with the transmission? Something I should know?
well i guess the 2004-2006 many or just the 05/06 auto transmissions are junk they had alot of issues even if you change the fluid every 10k miles but my 99 accord v6 trans was the same way i just changed it often and never had any issues with it and it has 210k miles and still kicking
RKinWA (03-01-2014)
mrgold35
I like the +06 models the best. The stock 06 model engine give you about 15 extra HP compared to the 04/05 TSX (a bigger bang for the buck on the 06 model).
Other upgrades:
-Thicker steering wheel with 10 & 2 o’clock grips/bumps
- Bluetooth
- upgrade NAVI with 650 voice commands
- Fog lights
- Different A-spec body kit
- Redesigned hood (no metal strip on hood from grill)
- Two position memory seats
- Car “beeps” when the alarm is set on the remote instead of “honking” the horn
- AUX connector in arm rest for MP3/Ipod
- There is no difference other than TPMS and $$$ when comparing 06 to 07/08 models
The 06 TSX is the "sweet spot" for the 04-08 TSX model years.
There is not much price difference between a navi and non-nave models; BUT, it will cost you some big bucks to fix if it is not working. I would stick with the +06 models with or without Navi (I like navi, dash looks better). I change my 5AT oil every 30,000 miles and no problems so far (110,000 miles now).
Other upgrades:
- Bluetooth
- Fog lights
The first generation TSX models (04 -08) are further split into two model groups. The 04 and 05 models, and 06-08 models. Both bumpers (f & r) are different (between the 04, 05 and 06-08), as are the hood, rocker panels, and windshield. The steering wheel, AT shifter are revised, added items are memory driver's seat, fog lights, and I'm sure plenty more parts that slip my mind right now. I'm partial to the 05's (presently have an 07, 010), but most would suggest looking for one of the updated models (06-08). I've never had the NAV, but it may come with it's own set of problems. Avoid the 04's, but otherwise they're pretty bullet proof.
Other upgrades:
- Bluetooth
- Fog lights
Other upgrades:
- Bluetooth
- Fog lights
ill take the extra 15hp lol yeah im going keep my eye on a 2006 forsure i wish someone was selling a white black or a gray one near ohio for 8k or less =)
According to all sources that I've seen:
The 2005 was rated for 200 HP and 166 torque.
The 2006 was rated for 205 HP and 164 torque.
In any case, I would make sure to buy a model that has a Hondata flash upgrade available.
would you happen to know what one that would be?
i need your guys opinion the 2006 tsx i looked at was pretty clean for 6400$ but the car would shake at stop lights maybe (motor mouth) ? and the air bag light was on also the vsa light was on could sounded little loud on take off maybe a small exhaust leak little bastard is tq taking off to lol compared to my 99 accord v6 lol i just wanna know what u guys think its on a dealer lot some foreign guys own it i really need a car and this is the only one ive seen for cheap and grey with navi =) with in 400 miles its 13 miles from me im welling to spend couple hundred to get it right if its worth it
Look here: http://www.hondata.com/wizard/wiz_tsx.html
From Road & Track magazine:
"These changes make for an especially strong-running engine, at least at high revs...205 bhp at 7000 rpm, and 164 lb.-ft. of torque at 4500. Compare this with last year's TSX (200 bhp/6800 rpm; 166 lb.-ft./4500 rpm) and you'd have every right to say, "So what?" Yet 2006's ratings are obtained using the new SAE J1349 standard (see Tech Tidbits, November 2005) that yields somewhat lower numbers. In an apples-to-apples comparison, Acura people tell us, the new powerplant is about 13 bhp stronger.
Read more: http://www.roadandtrack.com/car-revi...#ixzz2uuxx5V83
mrgold35
04-05 RL 300hp/+06 RL down to 290hp
04-05 TL 270hp/+06 TL down to 258hp
04-05 TSX at 200hp down to around 190hp under new testing
Acura had their HP numbers revised down because of some new SAE testing procedures they started using. The RL/TL engines remained the same for 04-08 years and it looks like the +06 model have less HP when it is the same engines with revised numbers. Acura increased the size of the TSX's throttle body, intake valves were slightly increased, cam duration and lift increased, and higher flow cat added to get the HP to 205 under the revised testing for the +06 Models. Acura did not change any of the before/after HP/TQ numbers so it looks like the TSX only gained 5 hp when it really gained around 15 hp.
Getting Hondata on a 04-05 TSX is like driving a stock +06 TSX. Hondata on a +06 will give you more bang for the buck.
http://en.wikipedia.org/wiki/Acura_RL
http://en.wikipedia.org/wiki/Acura_TL
http://en.wikipedia.org/wiki/Acura_TSX
mrgold35
You could check Carmax; but, the price you see is the price you pay. The good thing about Carmax is they only keep the better vehicles and they can ship a car to your location if find the color combo you like.
Also ebay. According to a car collector friend, it has become one of the top car sources for preowned cars. Of course, much like Autotrader, many of the cars would require shipping. But there are always a good number of TSXs available.
the 2006+ have different intake cams, and bigger intake valves than the previous years... and dont buy automatics, if you do get a tsx, get the 6spd... i hav a couple buddies that had to replace the trans b4 100k
mrgold35
I just looked and Kelley Blue book on an 06 in very good condition is $14K, (depending on mileage, etc. Could be worth more in excellent condition.)
I guess they do if they shake and shudder at stop lights have airbag warning lights going off, and other maladies, like that particular car did.
Just looked and saw that car. The record says it has been in two accidents, one with moderate damage. --No doubt that is why it is below blue book.
Oh btw, I've owned 4 TSX's and even at 104k miles, my transmission is flawless. Shifts are crisp. Downshifts are crisp. Shift logic is way better than most cars I drive. And the combination of this engine with this transmission is awesome.
On the contrary, I've driven TL's with less mileage where the gear shifts didn't feel as tight. Honda V6's and their auto trannies...
cycdaniel
12-17-2019 10:58 AM
divac
08-29-2018 10:13 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
