Bluetooth audio for the 1st gen, there must be a way
5th Gear
Hello all, I have been driving my moms new 2010 RDX for a few days a found that you could stream audio and telephone through the HFL. I was wondering if this could be possible on the 1st gen tsx (the 2ns gen have this feature). I know from some research that all the bluetooth magic happnes throught the bt module, thats the voice you hear and the cid display stuff. Is it possible ti swap the module from the 2009-2010 tsx into the first gen(by the way I have a 2006 navi). I am gonna go by the deler today and check that the pinout is the same for both modules.
mrgold35
I'll 2nd that request!!
I have a Blackberry 8350i and I have no way to play music in the TSX. The 8350i has a smaller AUX connector and adaptors don't work. I have a bluetooth streaming audio speaker at work for blackberry; but no solution for the car.
I would be happy to have a streaming audio module that connects to the TSX AUX to play. Anything is better than nothing.
mrgold35
This will work for the 8350i. Its not BT, but it gives you at 3.5 you can plug into the aux.
http://shop.crackberry.com/seidio-st...11A75A1556.htm
I will give this a try. I've tried two different 25mm-to-35mm adaptors (Radio Shack/Walmart) and they did not work very well. I've been using my 1st Gen Ipod touch instead; but, I don't want to carry around two devices when I leave the house.
MetalGearTypeS
08-29-2016 08:28 PM
navtool.com
31
11-16-2015 08:30 PM
