Blackberry pearl 8100 bluetooth & TSX
Hello guys, I need your help. Every time i try to make an outgoing call (punching numbers on the phone keypad) using my Blackberry pearl 8100 bluetooth to the TSX, it doesn't connect me to the tsx, and there's no ring tone on the fone itself nor the car either, until someone picks up and then I can only hear it on the phone. Is there any setting that allows me to make an outgoing call using the phone and automatically transfers to the car? My car is 2006 model. thanks so much.
Let me help you!
If you're linked, try hitting the HFL key and saying "Transfer." The system remembers whether you were using your handset or the handsfree last time.
If this isn't your issue, it may be an issue with your phone. In that case, your phone may not be fully compatible.
This may be the same thing as SoCaliTrojan said, but, assuming you're linked successfully (ie. you can make\take calls from HFL), try just pressing the HFL key once to activate HFL, and then dialing from your phone. That works for me with my phone.
MetalGearTypeS
08-29-2016 08:28 PM
Eggs999bacon
09-24-2015 10:08 AM
