Best aftermarket radio system for 04 tsx
This upgrade will make the whole radio/climate control unit in the center of the dash of your '04 TSX similar to what you would expect in a much more modern car. Very clean/OEM look install. Much cheaper and better looking than purchasing a double din radio with a separate radio dash kit (which would still have climate controls below, separate from the radio). I'm hoping to purchase one for my '08 TSX in the near future.
I've only heard of 3 complaints for it:
1. It runs Android 6.0, not the newer Android 9.0 or 10.0. I'm not sure if it can be updated to a newer version.
2. To get the time and outside temp for the radio, it basically steals them from your car (temp wont show on dash anymore, instead on the radio. And time wont show on the dash clock above the vents, also instead on the radio)
3. The temp can only be run in celcius. Again, I'm not sure if this could somehow be changed.
These are just the 3 complaints I've been able to find about it.
https://www.google.com/url?sa=t&sour...=1580546427293
Hello,
Don't buy any chinese all in one radio system with climate control, it will not be able to manage the temp correctly, you'll loose some function and finally destroy your climate compressor...
I've installed an 2din android audio system in my Honda accord, directly connected to the CDin input via an adaptor found on Ebay for less $15. My audio system a daisata MaX6 (PX6, 6cores, 4Gb/64Gb), it work very well. As I'm stil using original audio system & climate, all work perfectly.
Here are some picture of my installation. As I'm not really english fluent, I'll not explain how I've installed it, but pictures are good enough
06-08 radio compatibility
Is the 06-08 unit compatible with the 04-05 year models? My '04 has the lighting issue and I'm looking at my options as well. I've searched the web for a while and haven't found any solid answers.
