Another AC Question. Yay.
2006 TSX with 213,000 and never touched AC system. AC went form cold to hot while driving. Clutch is not engaging and relay and fuse are good. I tried jumping the compressor relay sockets (87 to 30) but to not get anything. Test light says there is power but there isn't even a tiny spark when i try to jump the relay. Relay socket (86) shows power from switch. Should the other socket (85) show anything when the car is running? Any ideas before I go too far into this?
If the clutch is not engaging and everything else is working normal then I'm going out on a limb and say that your A/C clutch is bad. You could rebuild the A/C clutch, but at this mileage I'd just go ahead and replace the whole A/C compressor just to be on the safe side. This is just my opinion, but hope that helps! LOL
