Acura TSX no heat but air blowing
I had an oil change done on my 2007 Acura TSX. Since then the heat is not working, especially on the drivers side. The air blows fine. Heating appears to be working on other vents but not efficiently.
My local garage is not able to identify the problem.
Any suggestions?
Any suggestions?
You need to bleed your cooling system.
This is the wrong forum though.
Also check air mix motor for smooth movement from max to min temp. They are a frequent source of heat/cool problems.
Problem should be similar for cooling, poor cooling control or stuck on one temp.
good luck
good luck
rockyboy
01-25-2016 06:00 PM
