Acura TSX 2004 Driving Performance question
I have recently gotten into an accident where I drove into a ditch, and ended up driving out with one flat tire. Thank god I am fine, but ever since this incident I have had a lot of problems on how my ride drives now. At first, every time I drove the car there was a noise coming from the suspension system. So I changed the axle. The noise went away, but now everytime I drive up to about 66-70mph the steering wheel shakes and sometimes the whole dashboard would shake too. So I got the roaders cut, but the shaking is still there. I also just got new tires..and I am planning on getting an alignment soon. What can possibly be the problem here?
If the shaking is occurring at 60-70 while not applying the brakes, having the rotors resurfaced won't help. The issue could be unbalanced tires. If you have a good amount of tread left on the tire have it looked at by a professional. You may also want to take it to a reputable dealer just to be sure you are not throwing money at parts that don't need replacement.
You probably damaged a lot more than just a tire. There are so many things you could broken, bent, or thrown out of alignment by ending up in a ditch, that a list here is not practical. I'd take it to a good alignment shop and tell then what happened. They may be able to determine what's wrong, if not, try a dealer and tell them the same thing. I'm pretty sure of one thing though, if you're dashboard is shaking on the highway? It's not just the alignment.
El Cunado
+1 .. I definitely think it's an imbalance
Start with getting all wheels balanced. Balancing involved the little weights that are attached to the wheel with an adhesive. You'll see them on the outside of the wheel behind the part you normally see. A good tire shop will balance them well and without taking a lot of time. It's also an inexpensive process.
It's a bent rim.
Just because the tires are balanced doesn't mean the rims aren't bent.
It is possible to balance a tire with a bent rim.
Make sure the ball joints are ok and not loose.
divac
08-29-2018 10:13 AM
Hau_nguyen91
09-06-2015 12:53 PM
