6 x 9 grill question
DC Metro Local Crew
hey guys, ive exhausted teh search feature and im thinking i might just be that dumb that i cant figure this out but...I was trying to replace the 6 x 9's last weekend and im going to try again this saturday. but i couldnt the speaker grill to pop off, i got the front to clips to pop up, but when i tried the back ones, nothing and i was prying pretty hard. is there anything ont eh other side in the trunk that i need to do anything too. if someone could please point me int he right direction on what to do, that owuld be great. i did a bunch of audio and speaker stuff to my civic that proved much easier than my 06 TSX. thanks in advance.
Rep'n Taxbrain.com
Originally Posted by gsclifton
From what I recall, you just need to use some more force to pop the cover off.
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
![](http://img303.imageshack.us/img303/840/dsc009379ow.jpg)
The grill has four anchor points. The front two are in those sqare looking holes closer to the seat. When you use something to lift on the forward edge of the grill these tabs pop out first. The second two clips go into the two round holes you see in the white metal deck on either side of the speaker. If you pull up on the grill then the clips should release (or break). You can access these clips from the the inside of the trunk. If you have someone helping you they can pull up on the grill while you pinch the clips in the trunk to ease their slipping thought the holes. Hope this helps.
DC Metro Local Crew
i wont have anyone else out there to help me. so are you guys recomending the pull forward and pop method, thatwill do the trick. the first time i was trying not to push too hard as not to break anything.
ABP TSX
Type-S user
Mine were hard to get out too... putting a flat screwdriver between the grill and 'steel plate' and wricking(?) a bit worked for me. Not broke a single thing.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
