2006 TSX rear bearing
7th Gear
After doing some research and getting price quotes from local mechanics here in jacksonville Fl. I've decided to turn this into a diy project. i checked all my tires and it seems the driver side rear bearing is gone, it looks pretty easy to change out just had some questions, should i change out just one or do the pair in the back, also I'm thinking about going with a timken hub are they good?
I have changed the left front bearing on my 04 after I slid into a curb. I think you can just change as needed. What symptoms of bearing failure are you having? If it is just tire wear, I think that is more an alignment/wheel issue
http://www.acuraoemparts.com/delray/...All&vinsrch=no
It looks like the rear bearing and hub are integrated in the rear. For a component like this, I would stick with OEM. You are going to realize savings from doing the work yourself. Don't skimp on the cost of the part.
Bearings are not a scheduled maintenance item. If you replace a bearing there is a real, significant probability of getting something wrong or bad part, and having an immediate (infant) failure.
I'm in the "if it ain't broke, don't fix" camp.
good luck
good luck
When I had my 2006, I was having bearing noise at about 140k, so I took it to the shop and he replaced a front one, but the noise didn't go away.
turns out the other front one was bad and a rear one too, go figure
I had him do the other front and I did the rear one myself
I didnt have a press to do the fronts.
7th Gear
Yeah I checked all wheels only heard one bad one which is driver side rear gonna change that one and see front ones I won't do I would take to mechanic for that
