2006 TSX - nearly 40,000 Miles, Gas Mileage seems to be dropping...
Still Lovin my 06
Anyone else experiencing this? My gas mileage on the highway used to be about 32mpg in the early stages. Now, even with cruise control going around 70mph, I cannot seem to break 29.5, usually even below that. It's the same route from NJ to PA that I use to compare, so the road conditions should not be different. If anything, the recently paved sections should help me, not hurt me. Any thoughts on why my mileage could be dropping? I check tire pressure, so that's not it. I can't think of any other littler things to do, but I'm willing to try anything for even small improvements.
Kind of like what they said. Upgrade to premium gas for a few tanks (if you are not using it already) and go and buy bottle of the fuel system cleaner/fuel additive from autozone (or a place of the likes) to put in your tank and then really push the car in the tank you have the additive you have. It should do the trick.
Poser / Fanboi
I'd say you're noticing the higher amount of oxygenates put in fuel in the winter but you should have seen that a while ago. Maybe the gas you bought recently had more ethanol in it than usual (did you go to an unusual station)?
Seems like OEM tires start to wear out at 40k - maybe your tread is wearing down and you have more rolling resistance?
Who knows...? I've seen this happen to me once on my 18k miles car and I just waited it out... something was in the atmosphere that month...
Couple factors: some fuel system cleaner additives can help (detergents), I don't do it as often as others, but 1 bottle every oil change seems to work. older / balding tires can hurt mpg too as your rolling resistance coefficient increases.
Now that I read it... what hunterk1 said. +1.
it's a car-drive it
My 06 6MT averages 32-36MPG (mostly highway driving). I try to buy my gas at WaWa or at Sam's club. My car, bought new 11/17/06, has almost 42,000 miles. I get the tires rotated and balanced between 6,000-7000 miles and check the tire pressure on a regular basis. The stock tires still have alot of thread on them and should last at least 8,000-10,000 more miles.
in the 24th and a half...
Originally Posted by jlukja
^^ fuel filter replacement is not a DIY job.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Still Lovin my 06
Originally Posted by rmjames007
I have noticed the same with my car in street driving but I also figure that it makes a difference where I get my gas
i usually fill up with sunoco 91 or BP (which is amaco).
Still Lovin my 06
Still Lovin my 06
anyways, i'm going to double check when the last time i had the tires rotated. i think i'm right around the 7,000 mile mark now, and that could simply be it. only problem is, sam's club doesn't do alignments (that i know of), so i'll have to go somewhere else.
does anyone think it's worth getting a new rim to replace the bent one? it's very slight, according to the tire guy
Still Lovin my 06
Originally Posted by EuroR08
Have you ever replaced your fuel filter or changed your air filter?
anyone that can provide me a description? i'll also search. i also need to change the cabin filter.
Still Lovin my 06
even if u pay someone to do it for you - it should majorly help your gas milage...
^^ check the other thread. The fuel filter is really just a fuel strainer, but its located inside the gas tank. Its not meant to be user replaceable and is not part of any maintenance schedule. SoCaliTrojan found a reference quoting that the fuel strainer is good for the life of your car.
On another topic, and just food for thought, this past Christmas my brother gave me a membership to Costco. So, over the past 3 months I've been filling up with Costco brand 91 octane. My mileage has dropped by roughly 2 mpg in this time period. I thought it might have been the weather, the winter formulation, my tire pressure, etc. But, last weekend we drove down to San Diego and I filled up at Shell and my mileage is back to "normal". So, I think that there may be a difference among brands, and if not brands then maybe this particular Costco station just carries bad gas.
Still Lovin my 06
i do need to change the air filter and the cabin filter, but i don't think either of those things will help.
you're saying there is no reason to change the fuel filter?
i'll rotate the tires and take it somewhere for an alignment. i'll also pick up some additive to put in the next fill up. we'll see.
it's a car-drive it
i'll rotate the tires and take it somewhere for an alignment. i'll also pick up some additive to put in the next fill up. we'll see.[/QUOTE]
I would first get the tiresrotated and balanced-you might not need the alignment.
I replaced air and cabin filters at about 27,000 miles-MPG stayed the same.
Still Lovin my 06
I replaced air and cabin filters at about 27,000 miles-MPG stayed the same.[/QUOTE]
that's around where i got the maintenance minder for that. i figured i'd do it myself, and at 39k, i haven't gotten around to it even though NAPA is 4 blocks away.
i will rotate/balance first and see what happens. starting this thread made me realize i was probably close to needing that as i started to type.
alignment will be step 2. i'll throw in the additive just for good measure.
Still Lovin my 06
Yes. Acura's position is that it doesn't need changing and I'll agree. First, its probably a PITA considering where it is mounted. Second, even if it was clogged a little it shouldn't affect your fuel economy unless it was so clogged that the pressure drops and the fuel injectors do not deliver the proper amount of fuel. If that were the case I would imagine the ECU would note that and the CEL would come on. I think a fuel additive should be your first step, let it try to clean out the filter, the fuel lines, and throttle body, and the injectors.
goog call, thanks!
gets all the crazy chicks
Old Man Yelling at Clouds
study after study has proved that brand of gas does not affect mileage.
For the OP - all good tips here. I'd maybe try another gas station. I would not rule out tires or alignment. Did you recently use a different type of oil?
i've noticed this over a period of about the past year. i have already replaced the OEM tires, i think it's the comparable goodyear brand, forget the model.
The OEM tires usually have very good rolling resistance (and often at the expense of noise, grip, etc). Replacement tires tend to better in the areas of grip, but they are rarely low rolling resistance tires. This can cause a huge drop in fuel economy.
![Smile](https://acurazine.com/forums/images/icons/icon7.gif)
What's up bradykp...
I haven't heard you for a while hommie... Remember our purchase back in '05???
I miss my crazy thread "how much you paid for your 2006???" ahahah
Anyway, i have the same issue with 45k on the car.... Gas milage is crap... My friend on 330xi has better milage. It's pathetic...
I dont know what to do...
Plus accelaration on the car got worse, takes forever now....
I would definitely change the engine and cabin air filters if you haven't already done so. The air filter can have a huge effect on the MPG. Some people claim that a clogged cabin air filter could potentially affect fuel economy as well, as the electric fan motor would have to work harder to push the air through the HVAC system, which could cause a drop in fuel economy. Not sure if I buy into that, but I'd still change the cabin air filter as those tend to look fairly nasty after 15k.
Originally Posted by SodaLuvr
That's probably why.
Still Lovin my 06
i'm not convinced it's the tires. it is the comprable goodyear model to the michilins, and from what i have heard about the mich's, they were pretty crappy. plus, it didn't happen for the first 5k or so the new tires were on.
i did just get the tires rotated and they told me the rear tires were wearing unevenly, so i am taking it in for acura to look at the alignment and the rear shocks.
comes to think of it...my 05 auto just turn 45000 miles and the milage i am getting is 23mpg on the free way??? I drove about 75 mph with 2 adults and 2 kids. It shouldn't get down that low....90% free way and 10% local. I had new set of tires...Falken ze ex 512, they are noisy.
Still Lovin my 06
The Michelins may be crappy as far as grip goes, but the OE Michelins tend to have extremely low rolling resistance compared to aftermarket replacements.
regardless, it cannot be the tires, since i've experience the good gas economy with these tires for at least 5k miles.
took the car in today for alignment, they said it did need it.
Still Lovin my 06
Still Lovin my 06
so we took the car for an alignment today. this is my first car that i am responsible for, so i'm not familiar with all maintenance costs. wondering, is the $99 acura charged us outrageous for the NY metro area? we're in jersey. i've heard i probably could get it done for $75-$85, but that's not a difference worth shopping around for when the car was already at acura
