2006 TSX Aux and Bluetooth Audio
So I made a previous post about this but there was no way to edit the title and I have learned a lot since yesterday.
I just bought a 2006 TSX with Nav and I get no audio from the HFL (even though it responds to voice commands) and I get no audio from the AUX input in the center console.
I have discovered that both the Bluetooth and the AUX input use 10-pin green harnesses that lead to the back of the radio/navigation unit. It my car however, the don't plug into anything. I would think that they should plug into a harness that passes them through to the 14-pin (I think) harness that plugs into the bottom of the Radio. After a lot of searching I found that the Pin out for the 14-pin harness that plugs into the bottom of the radio does have wires for Aux Left, Aux Right and Aux ground. So my green 10-pin coming from the AUX jack must pass through that connector somehow.
Anyone have any ideas at this point on where to find a connector?
Thanks for your help!
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
