2005 TSX recall?
#41
Just called in the 800 number and the rep said currently my car does not fall under the recall range of VIN# for now atleast; however, since the recall is so recent they are still generating a more complete range everyday. He said they will be constantly updating the VIN range until the end of March and notify owners at that point. So I guess you won't know exactly if you're safe until they generate the final list.
#42
Originally Posted by G36
Interesting no one has asked where the relay is located! If easily accessible, one can check which name brand is installed.
#45
Originally Posted by TSX2345
I just called them. You will know if you are affected when you receive notice. I tried to get her to give me the VIN range, she couldn't for some reason.
She said I was affected.
vin range is given here
#46
Originally Posted by ASpecTSX
I just called and luckily my VIN is not within the affected range. Although, they did tell me that there has been another recall on 05's (and possible other years) regarding the HID headlight assembly. Apparently where the hood contacts the headlight housing it causes some rubbing that will deteriorate the seal over time allowing moisture to enter the headlight. They said that the HID notices were sent out on March 9th.
I've already had one headlight replaced under warranty due to moisture about a year ago so it looks like Acura is finally addressing the problem. Hopefully some of you guys that are out of warranty could benefit from this new recall.
#47
Originally Posted by Tsx6363
http://www.in.honda.com/Rjanisis/pubs/SB/B07-017.PDF
#48
If you car is affected, for any type of recall, there will be a letter in the mail. Recalls are a totally different story than a TSB.
Now, speaking of TSB's, does anyone know where to access this for informational use?? Used to be , years ago, this information was readily accessible on the Web, for free. Not so any more. I believe the reason being, to may people were accessing this info to have service done to their car while under warranty, costing the MFG's to much $$. The TSB is nothing but a notice to dealers in case a customer has issues with whatever minor problems occur with their vehicle that has been registered withe MFG, due to so many customer complaints. This means the MFG. has acknowledged there is an issue, but won't address it till the customer has a complaint about that issue.
#49
#50
Aww, I'm number 024966... 209 cars after mine were affected. Being that I have such a late model 2005, I'd say 25175 was the last production number given to a 2005.
-Shaun
-Shaun
#51
I checked with the dealer today and the service advisor indicates the problem vechicles are produced after mine that was bought in early 05..... so.. I think the problem vechicle are all produced in mid or late 05.
Also, for those in Canada, there are in total 1500 approximately vechicles are impacted.... including all other Honda models beside TSX.... there are not too many of TSX to be impacted in Canada.
#52
Originally Posted by MichaelkTSX
Longer cranks seems normal in this I4. I have the same problem in my old 03 Accord with the same engine. Most likely it's the crappy OEM battery.
The longer crank time is for emission control on the tsx. It sucks.
#54
Originally Posted by PWPTSX
how does longer crank related to the emission???? i thought that it was just the crappy Panasonic battery............
After I switch out the OEM battery crank time got better unless its cold. The OEM battery always had a long crank time no matter the weather.
#55
#56
Originally Posted by Howard911s
04 here.. thank god, but just wondering, 04 hs 200 HP, 05 and 06 has 205 HP, does this have anything to do with them tweaking the engine to pump out 5 more hp?
#57
I drive a silver 2005 TSX auto. I'm a newbie to this forum. I found you guys by googling the recall issue.
We're checking our car today. We have had absolutely no problems with it except a cracked winshield from an oversized truck that cut us off and spit rocks all over the windshield.
Never experienced any of the symptoms related to this recall, but we're still checking it out.
T
T
#58
-Shaun
-Shaun
#59
So how does the recall work if I'm past the 50k mi warranty period and my VIN falls within the list of recalled vehicles? I don't have any problems so far (knock knock), but I know that I should have this recall work performed.
If I have the recall work done, do they give you a 90-day warranty (or anything) if you are out of the vehicles 50k mi warranty period?
#61
Driver/Detailer
#62
-Shaun
-Shaun
I think I bought the very last 05 TSX. Almost ALL dealers were sold out, and we found a dealer that was getting in one last shipment. Mine is 033053. Beat that
#64
Originally Posted by handydandy
i have a 2006 tsx, and if my vin # is jh4cl...C025672
do i fall into this?
#65
Originally Posted by tf500
Yeah,i'm in Aust.and it looks like we've got the recall as well.Mine's an 06 and it looks like mine falls within the vin nos.stated.
#66
#67
It's a recall, doesn't matter about age or mileage!!
#68
I fall into this recall range. So do we wait until we get the official notice in the mail before we can take our cars in for the repair?
I noticed over the past few months my car has been taking longer to start, it just cranks over and over sometimes and feels like it wants to stall out right after it started up. Its an 05 auto btw. Doesnt happen all the time maybe 3-4 times a week out of 70 trips.
#69
05 SSM TSX 5AT
Hey guys took my 05 TSX for a 30,000 mile service, and they knew about the recall to the relay line.
The happened to have the part in stock and performed the main relay update under my warranty.
Also, they performed the head light lens bulletin (adding some clips) that prevents the tsx headlights from getting condensation.
You could maybe try calling your dealership and seeing if they can perform the recalls early.
#70
#71
Originally Posted by Newcleannow
2005 RL – From VIN JH4KB1...5C016266 thru JH4KB1...5C020997
2005 TL – From VIN 19UUA6...5A046061 thru 19UUA6...5A067961
2005 TSX – From VIN JH4CL9...5C018626 thru JH4CL9...5C025175
my 05 tsx is not in that range. where did you get these number
#73
Sorry to bring up an old thread, but did anyone that have this problem still hear the fuel pump working when turning the key to ignition 2? I think I have this problem on an 04, but I'm not sure..
#74
My 2005 RL has cut out a few times at 65-70 miles an hour. This is extremely scary. I'm really annoyed that Acura did not contact me. I will be calling them this morning to get this repaired.
#75
El Cunado
Hope you can get it fixed. This happened before I owned my 2005 TSX so I wouldn't have gotten a notice. My VIN is not in the range, so I should be okay as long as they never increased the range.
#76
I checked and I am in the VIN range. I called Acura and they told me that the repair was done in 2007 before I owned the car. I checked the relay and it is the defective Mitsuba relay. Las Vegas Acura wants to diagnose the problem and charge me for the diagnosis. Does anybody know that if they did the recall would they be replacing the Mitsuba relay with another Mitsuba relay or did the dealer a few years ago just take Acura for a ride and say that they did the work when they really didn't?
#78
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
Joe Avesyan
09-29-2015 03:57 PM
