2005 TSX recall?
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
Saw this on the TL forum, heads up for 2005 TSX owners
https://acurazine.com/forums/showthread.php?t=155366
http://www.azcentral.com/business/co...call19-ON.html
Honda recalling 165,000 vehicles over engine problems
Associated Press
Mar. 19, 2007 09:30 AM
WASHINGTON - Honda Motor Corp. said Monday that it was recalling about 165,000 vehicles from the 2005-06 model years in the United States to deal with potential engine problems.
Honda said the recall affected 2005 models of the Acura RL, TL and TSX sedans, 2005 Honda Accord coupes, sedans and hybrids, 2005 Odyssey minivans and 2006 Ridgeline trucks.
The move is part of a global recall because of similar problems, said Honda spokesman Chris Martin. Details on the total number of vehicles and the number of countries where the vehicles were sold were not immediately available, he said.
advertisement
Martin said the automaker discovered that sealer material leaked onto a coil wire inside the fuel pump relay on some of the vehicles. The wire can become brittle and snap, causing the engine to stall or fail to start.
Honda has received "multiple complaints" of vehicles stalling or failing to start, Martin said. There have been no injuries or crashes linked to the defect.
Dealers will inspect and replace the fuel pump relay free of charge. The recall is expected to begin in early April.
Owners can contact Honda at 1-800-999-1009.
Associated Press
advertisement
Interesting. Wish they'd do one for the headunit though on the '04s. I've been lucky with that so far, but watch me get unlucky right after the warranty is up.
A DiRTBAG decal on my
I just called them. You will know if you are affected when you receive notice. I tried to get her to give me the VIN range, she couldn't for some reason.
She said I was affected.
The fuel pump relay failed on my 05 TSX a few months back while driving down the highway. It was not fun to be driving at 70mph and having your engine cut out on you, so this one everyone may want to get this fixed asap.
If your engine cuts out while driving, make sure you pull over somewhere safe as quickly as you can -- my steering locked up about 20 seconds after losing power.
I would imagine this is covered by the powertrain warranty.
Trolling Canuckistan
Originally Posted by thenewrecruiting
Where can one fine the serial # lists to see where they fall?
The denso relays are fine.
The mitsuba relays need to be replaced. If you have a mitsuba relay, your VIN will be on their list.
2005 RL – From VIN JH4KB1...5C016266 thru JH4KB1...5C020997
2005 TL – From VIN 19UUA6...5A046061 thru 19UUA6...5A067961
2005 TSX – From VIN JH4CL9...5C018626 thru JH4CL9...5C025175
So it's only for 2005 right? I bought a 2006....whew.
Originally Posted by minkl81
mines #1945 not in the vin range for the recall. maybe i'll stop by at the dealer and ask if it can be replaced under recall.
Bye TSX, hello domestic?
Goon!
Sometimes dealers screw up more than they fix. I took my '05 TitsSX in a few months ago to have the passenger side seat heater switch replaced. They "replaced" the passenger side one and the next day I was driving at night and noticed that the drivers side switch backlight wasn't working. I think they just switched it and hoped I wouldn't notice. Bastards!
hmm mine falls into this range. I guess ill have them do the work when I take it in for maintainence anyway. I've never had my car stall or completely not start but lately it will act like its not going to turn over once in awhile.
Originally Posted by S14 n Tsx
shit! mine is C02382. I didn't had any kind of problem with my engine though. I guess I should take it in to make sure.
HOWARD911S
04 here.. thank god, but just wondering, 04 hs 200 HP, 05 and 06 has 205 HP, does this have anything to do with them tweaking the engine to pump out 5 more hp?
Originally Posted by str8 tsx
JH4CL9...5C03....
I'm safe.
I'm safe.
Originally Posted by dalieu
Same here, but a couple times lately my car needed a 2nd crank or a "longer" crank... I'm going to ask when I take my car in for an old change anyways.
Originally Posted by TSeXy_Grl
new to this site but i like what i'm seeing in terms of knowledge
. i have a 2006 but i get the same thing (longer crank)
. is it because of the winter and cold days?
Just last week my car would not start and just kept cranking over and over. Finally it started.
I just brought my car in for service too (and like the other person said, my seat-heater switch no longer lights up) and had the center console fixed.
I just called and luckily my VIN is not within the affected range. Although, they did tell me that there has been another recall on 05's (and possible other years) regarding the HID headlight assembly. Apparently where the hood contacts the headlight housing it causes some rubbing that will deteriorate the seal over time allowing moisture to enter the headlight. They said that the HID notices were sent out on March 9th.
I've already had one headlight replaced under warranty due to moisture about a year ago so it looks like Acura is finally addressing the problem. Hopefully some of you guys that are out of warranty could benefit from this new recall.
Originally Posted by G36
Interesting no one has asked where the relay is located! If easily accessible, one can check which name brand is installed.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
