2005 tsx non nav stereo upgrade
Old May 21, 2012 | 02:02 AM
ptowntsi's Avatar
3rd Gear
So If I get mercmans harness to use the balanced level line input signal to the JL amp, can you use the pre-outs on the JL to power another subwoofer amp?
Do the old 300/4 JL's accept balanced level input?
I'd like to use a 300/4 or similar for our 2005 non nav TSX system, and then run a small 500 watt mono sub amp from the pre-out channel output of the 300/4.
or would i need to use another balanced level amp like the JL 500/1.
The system for the TSX would likely consist of:
Infinity perfect 6.5 front components
6.5 infinity kappa coaxial in rear doors
remove rear 6x9s.
JL 300/4 for front/rear and a small D class 500 watt mono amp.
12" digital design 3500 series sub in the trunk.
handsom-hustla
Nov 13, 2015 05:04 PM
ivegotthenav
Sep 11, 2015 07:51 PM
brjones9
Sep 3, 2015 07:30 PM
nuldabz
Sep 3, 2015 05:49 PM
