06 acura tsx electrical issue
this is weird. When I turn on the headlight of my car, the rear passanger windows goes down. It doesnt come up until I turn off headlight and pull the window up button. Has anyone have this issue? How would I go about fixing it?
2nd issue, the air bag sign comes up saying Check air bag system, it appeared twice so far in alst month. I park my car and when i return home int he evening the sign disappeared. anyone had this issue?
I had some problems (windows would not operate) w/ windows on 07 Accord (tsx is similar) when water got into the door (window left down). I left in garage w/ windows down for a day and problem resolved. The multiplex control unit is in the driver's door.
There have been many reports of SRS light on due to seat belt connection switch faults. Search for discussions on subject. Check w/ Acura whether it's covered by warranty. See following link to access SRS codes and determine if seat belt fault is likely. http://forums.clubrsx.com/showthread.php?t=636707
good luck
good luck
