Eibach Sportlines versus Pro Kit for 2.5TL
Alright guys, I have a question for you all. I am looking into getting my 2.5TL lowered. I narrowed my choices down to Eibach Sportlines or Pro Kit. I plan on using my stock shocks for now. The Sportlines are 1.7" Frt/Rear while the Pro Kit are 1.2 frt/1.0 rear.
Any thoughts? I am leaning towards the sport lines.
'13 Hyundai Sonata
What do you plan on doing with your shocks? If you're going to do aftermarket shocks (ie. koni yellow, etc.) from the Accord then it'll slightly lower your car and then the Pro Kit is the way to go. If not, then the Sportline is what you should do
Thanks for the input - I think I'm going to stick with stock shocks for now and then probably switch to a better suspension set-up when the shocks go. I am lowering because i want an aggressive stance and a tighter suspension. The stock suspension is too soft for me and feels 'old'.
I think I'll go with Sportlines. My only concern is that the Sportlines will put more stress on my shocks. I also read that the spring rates are quite similar so it should be fine.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
