19-20 tire size??
19-20 tire size??
well its been quite some time since i had wheels on my car. I used to have a racing hart c5 19x7.5 and i honestly dont remember the offset now. Theres probably pictures on here some place but either way....
I was running a 215 35 19 tire im pretty sure. My question is... Has anyone ran a larger profile 19 inch tire with little to no issues with rubbing.
The 19s i had had little problems with rubbing unless it was pounded which does not really matter what size wheels you run at that point.
I am looking to get a little more sidewall because the 35 series is not enough for a 4 thousand pound car with cincinnati roads.
My 19s were bent in a few months and I had multiple impact bubbles from broken belts in the sidewall. Id like to get something thats a little larger for a 19x7 inch wheel.
Also those of you out there running 20s do you suffer these same instances with bending wheels and so forth.
Are there significant issues with rubbing on these 20 inch wheel ua's
Im thinking the 20 inch deal is a "ridin high" big wheel type ordeal from the sounds of it. I dont want some jacked up car. I want to be able to lower it, and have the inspired motorsports lip kit so it wont be so high and may benefit from larger wheels
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
