Where does the 2.5 exhaust manifold crack?
Old Nov 21, 2010 | 08:39 PM
THATPRELUDEGUY's Avatar
I'm trying to get a fix on where the exhaust manifold cracks and if there's any way to do a half ass job of repairing it just to get through inspection. Could someone give me an idea of where the crack occurs?
Old Nov 22, 2010 | 12:12 PM
TexasHonda's Avatar
My recollection is where the individual pipes join the catalytic converter/header. I think it was the mid pipe that was cracked. Difficult to access for welding. I took to one shop and he didn't want to try to weld. I've read of others w/ successful repairs though.
Note, this is SS410 steel, a type of stainless. It is weldable w/ steel consumible, but this will damage the anti-corrosion properties. Proper welding would use a SS consumible.
good luck
Old Nov 26, 2010 | 11:10 PM
I wonder if I can use somethng like JB weld for a short time solution just to get me through inspection.
Old Nov 27, 2010 | 09:13 AM
TexasHonda's Avatar
I'm certain J&B weld won't work. Epoxies will melt/burn at 1000+F temps where the intake manifold runs. There are some muffler cements that might temporarily hold, but I'm doubtful. I seriously doubt you can get to the crack w/o removing the intake manifold. If you do that, you for sure want to repair or replace the part.
good luck
Old Nov 29, 2010 | 07:17 PM
leonardobubbico's Avatar
5th Gear
its a real pain to get it out. i have just welded my exhaust manifold about a month ago. Texashonda is correct. my break was completely around the middle pipe at the cat. worked quite well exept im an amatuer welder and i used a home depot 90 amp welder. i might need to pull it down and hit it again. That part happens to cost $500 - $700
Old Nov 29, 2010 | 07:25 PM
TexasHonda's Avatar
Try searching car-part.com for a used exhaust manifold near you, go by to inspect, and purchase if good.
good luck
Old Nov 29, 2010 | 07:59 PM
5th Gear
maybe its a ny thing but i believe you cannot purchase a used catalytic converter which happens to be attached to the manifold. bad news for me.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Jul 16, 2017 07:33 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
johnpancakes014
Sep 27, 2015 12:58 PM
