speaker wire colors?
What are the speaker color polarities for the tweeters behind the radio? The green ones? Thanks?
it is a a separate harness... it is small separate and has 4 wires coming out of it...
here are the color codes.. 1998 Acura TL Stereo Information Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger n/a Antenna Rear Window Front Speakers 5 1/4" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 5 1/4" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White |
Thanks but that still does not help, My TL has 6X9's in the back and those are already hooked up. The polarities I needed were the green wires that are in the seperate harness on the factory radio. These are the wires that run to the mids in the ceiling and the tweeters near the "a" pillar. Thanks again.
I'm trying to wire up my amp converter.and thought the easiest place would be in the passenger kick panel.ive pulled the speaker wire harness out of factory amp,but can't find a wire diagram that I can trust.most of the ones I've found dont have same colors.any help would be great.just need the rear speaker colors and the constant 12v and switched 12 v colors grounds black I know.thanks guys
And its in a 2004 Acura tl my bad lol its still early and bitter cold out today!
