No spark... Number 1 and 2 cylinder
Hi first time post.
1997 Acura 3.2 TL Premium
No spark in number 1 and 2 cylinder. Replaced spark plugs in bad cylinders, no spark. Swapped coil paks still no spark. Replaced Egnition control module no spark.
Each connector going to the coils has 12 volts even on cylinder 1 and 2.
Symptoms,
Car ran fine then wife started car and it shook, she turned it off immediatly and i hooked up an OBDII scanner. Codes that showed up are.
P0300
P0301
p0302
P0399 Pending.
Any ideas would be greatly appreciated
Symptoms,
P0300
P0301
p0302
P0399 Pending.
I was browsing the forum and came upon the Extended Emissions Warranty.
I have not used this warranty, due i just take it to the Acura dealership or due i need to call the 800 number? Will it cover the symptoms the car has?
A little help i found a member who has had similiar issues with his Acura, however i can not message him. I am told i do not have privelages?
His Username is dubcnea
I would like to know if he resolved his problems.
Khmer Pride
did you get your self a tuneup? there probaly oil on the bottom of the cylinder..thas what i readed
You swapped coils with which known good ones?
I swapped coils with 5 and 6. Both of these showed spark when tested. Actually all had spark except 1 and 2. However the spark wasn't very strong.
Know i have it all put back together put the negative post back to the battery and now no codes?
Got it started codes are back same ones. Car still stuttering. I called Acura and they told me the Extended Warranty should cover all powertrain issues. I will have it towed to the dealership tomorrow.
I will let all know the outcome and solutions to this problem
SidhuSaaB
05-30-2020 12:40 AM
emailnatec
29
09-28-2018 04:27 PM
jterp7
3G MDX (2014-2020)
02-03-2016 08:34 PM
joflewbyu2
10-08-2015 11:16 AM
