Issue with keyless entry
So apparently my keyless remote won't let me lock the door, but i don't think the battery is the issue since i can still unlock the door? Anyone have any idea how i can fix this?
Did you try reprogramming the remote? Open only driver door, hold unlock button up now stick key in ignition 5 times within like 10 seconds and a sixth time keep it in the ignition until the locks cycle then push the button on the remote-either button. Then just take key out of the ignition.
mgis (08-17-2011)
The little microswitches on the circuit board separate from the board at the solder jts. If you are equipped for microsurgery, you might be able to repair. I tried and could not.
Check ebay for a replacement remote key.
good luck
good luck
tman570
06-11-2019 07:56 AM
09-17-2015 09:01 PM
RenoTL
09-17-2015 07:45 PM
