How do I get to my instrument cluster lights ?
i want to put new led lights in my instrument cluster to update the look of the car. how do i get behind the glass and instrument cluster to the lights ?
大日本帝国
There are eight screws, and a bunch of tabs. The first two are behind the flap above your steering column. The second two are at the top to the curve, facing down.
Then you have to gently pry the vents out, as they have tabs above and below them. once that's taken out, there are four more screws holding the lens and cluster in.
Wiggle it out, disconnect the harnesses, and then you can slide out the cluster. Be ready to have to adjust it several times because of the polarity of the LEDs.
Unlike almost everyone else's, my LEDs work either way so I don't have to worry about that, .
~Cheers~
~Cheers~
rockyboy
08-04-2024 10:35 AM
09-15-2015 06:44 PM
