changing axle
If you haven't changed recently, it should be drained before removing the axle and replaced w/ new fluid. I recently replaceed this axle and replaced fluid w/ new synthetic transaxle lubricant (walmart brand).
good luck
good luck
I went to the honda site and found diy on this but not sure if it was the same for my car. I'll just follow the directions and see where it takes me. I'll also change the fluid before I do change it. Thanks for you help
