Can some one identify this car part
Old Oct 23, 2011 | 03:04 PM
fire919's Avatar
Hello all, my car is running hot very quickly...it appears that when i put water/coolant in my radiator, there is a pipe that is located behind the alternator that has a hole in it and is leaking all of my coolant as so as i start fillin my radiator....can someone tell me the name of this "pipe like part"...and do any of you know where i can but one from. thanks in advance, your help is lways appreciated
my car
2.5l 5cylinder
Old Oct 23, 2011 | 03:09 PM
tempetom's Avatar
Is there a hose from the radiator neck to the coolant bottle? I can't think of anything else.
Old Oct 23, 2011 | 03:15 PM
fire919's Avatar
yes there is but that appears to be fine....also don't kow if this problem causes this to happen....but the coolant in the overflow bottle reservoir be boilin crazy hot
Old Oct 23, 2011 | 03:35 PM
KrayzieDxC's Avatar
Khmer Pride
my car
2.5l 5cylinder
thats the part , where you drain from the engine block..you need to fix that..and seal it.. its might be a pain in the ass to get thur..
take a picture? if u can it be helpful..
Old Oct 23, 2011 | 08:37 PM
fire919's Avatar
imma try to take a pic 2marra...thx for response
Old Oct 24, 2011 | 08:55 PM
KaMLuNg's Avatar
Pic update?
Old Oct 27, 2011 | 04:11 PM
fire919's Avatar
I actually can't take a picture, make camera is jacked....however i probably can do one better
the pipe that i was reffering to is labeled 8
...after leaving it @ mechanic it was dicovered that the water pump '1'and housing 'not labeled' were bad also
Old Oct 27, 2011 | 04:12 PM
fire919's Avatar
anyone know where i can find water pump housing
Old Nov 12, 2011 | 08:36 PM
Acura TL 2.5 (INSPIRE)'s Avatar
hello there, i hope this part number helps 19200-P1R-003 w/pump about $100 and w/pump gasket 19222-PV0-300 about $2-$3
just copy & paste the part numbers on google and you see the results
Old Nov 13, 2011 | 10:36 PM
bigwerm187's Avatar
Str8 Home built
Thats alot go to rockauto.com lol i just did my timing belt and water pump.. lol
Old Nov 13, 2011 | 10:40 PM
bigwerm187's Avatar
Str8 Home built
For 210 bucks i gor a radatior, water pump, timing belt , timing belt tensenor up and lower coolant hoses the water pump came with the gasket too lol all for 210 with shipping included
Old Nov 14, 2011 | 10:03 AM
tempetom's Avatar
I liked Rockauto's prices, but they sent a lower coolant hose that didn't fit my 3.2 even though the part number on their site agreed with it. I had to eat the $8+ shipping which was $1 less than the part cost.
I'll factor all that in if I ever go to them again.
Feb 25, 2020 09:57 AM
tonio
Feb 5, 2019 05:43 PM
handsom-hustla
Nov 13, 2015 05:04 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
