bearing noise
bearing noise
my car sounds like a tractor, and the sound is the worst when you are inside the car. outside its not nearly as bad.
I have a suspicion its my differential, but I am hoping its the wheel bearing.
I jacked up the car, put it in drive and noise was there; took off the wheels, noise was there.
When I try to wiggle the wheel, it doesn't move.
couple of weeks I replaced my drivers axle because the inner joint was messed up. the boot was fine, but the interior was not moving smoothly.
any ideas?
any ideas?
If wheel bearing is bad you can usually feel the roughness by turning the wheel manually w/ a hand on the axle retaining nut and shaft end.
It's more likely the replacement axle is bad. I've seen horror stories of aftermarket axles requiring 2-3 warranty replacements before finding a good axle. I buy a used CV axle if I need one, and try to watch the boots and repair the boots before CV axle is damaged by boot rupture and loss of lubricant.
good luck
good luck
turned out to be the bearing.. separated the axle from the hub and the grinding is definitely in the hub.
i got my axle from EMPI.. hope its good..
thanks texas.
thanks texas.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
