Battery Negative terminal
Old 02-08-2010, 02:19 PM
fire919's Avatar
If you open your hood does anyone car have a single wire that runs from the engine block the battery negative to what looks like a fuse panel if so is that the only connection on your batteries negative terminal can u post a pic so i can put mine back? it was on mine and i've removed that wire and run 1 wire from engine block to battery negative and another from battery negative to chassis.
Old 02-08-2010, 02:33 PM
'13 Hyundai Sonata
TLin401's Avatar
Post a pic. I'm not really understanding what you are saying.
Old 02-08-2010, 02:37 PM
fire919's Avatar
what wire(s) is connected to your battery negative terminal. what is it connected to at other end.
Old 02-08-2010, 09:49 PM
desired_speeds's Avatar
the chasis and the engine block.
Old 02-08-2010, 10:13 PM
fire919's Avatar
dang....that took ah minute....thanks bro, just wanted to confirm thats everyones connection
Old 02-09-2010, 12:22 AM
大日本帝国
Go90go's Avatar
So did you try out those bulbs?
~Cheers~
Old 02-09-2010, 08:36 AM
fire919's Avatar
O yeah...i haven't gotten to em yet actually but when i do i'll link u up
MetalGearTypeS
08-29-2016 08:28 PM
jdmaszfcuk
10-19-2015 12:31 AM
iesu3423
09-29-2015 08:04 AM
Quick Reply: Battery Negative terminal
