Anyone Noe How To Remove Rear Seats On A 96 2.5 TL
Str8 Home built
On day i was puting in my stereo. and the power cable my TL came with was an 8gauge and i wanted to change it to a 4gauge. well i put evything eles on my car but i could remove the rear seats. i juss couldnt figur it out. the good thing was that the 8g wire was already in the trunk so i put the 4g wire taped to the 8g wire and pulled it through and wen i had all of the 8g wire out i took it of. so out of everything to my Tl i have done i havent had a problem i always end up finding out how to do it. but the rear seats i couldnt figur thins one out. i want to take them out so i can put me seat belts out. there under the seat and i need to get them out. i tired to pull them out but they juss wont so i got to remove the back seat. Do can some one plz tell me how to take out the back seats. thanx ppl..
'13 Hyundai Sonata
This should help. I just found this in an old thread.
Removing rear seats
these are surprisingly easy. The trick is to start with the one bolt holding the bottom seat on. It's located right behind where the seatbelt latches stick out on the driver's side. I think its 11mm, and you'll need a socket extension. Pull seat bottom up from front and remove. There are three more bolts holding the seatback on. (On the bottom, one on each side, and one where the other belt latch is mounted. Slide the seatback up a couple inches and it will come free. This takes a little effort.
Removing rear seats
Str8 Home built
oh k. yeah i thought the seats would fold down like other cars do. ok thanks man ill go look for them. i got a Question 4 u Big Balla... how od u make your coner lights on the headlights come out white..? i changed the bulbs in mine to while and the light still comes out to like that popo brown color... why is that..? and i got the xenon whites.
'13 Hyundai Sonata
Str8 Home built
I have LEDs in my corner and parking lights. I think that with the LEDs on and the headlights on with the foglights off the car gets sort of a VIP look. Then when it is raining, dusk, dawn, or foggy I roll with the foglights and the parking on and I get looks all the time.
rockyboy
08-04-2024 10:35 AM
