AC Heater fan stoped working...HELP...!
Str8 Home built
The fan in my 2.5 TL dont work it use to the other day but it stoped working today. not my radiatior fan but the one for the heat and AC in the car. i checked all of the fuses and none of them are blown so yeah any ideas on how to fix this problem.? all my lights for the ac heater light up and the fan does to but the fan aint working. i can here is working for 2 sec then it stops... plz help...! thanx....
Do you have the display workig right?
It must be your blower motor that needs to be replaced. It's a PIA to replace it. the dash needs to come out.
No easy solution for it.
Str8 Home built
dang realy..........!!!!!!!!!! yeah everything in my dash is working right.. i heard it want to work to for a bit so yeah. is there any relays that go to it that are hidden that i can check. if there is sum were can i find them.? cuz i want to check all that stuff before i think of changing that blower motor.
Our cars have A/C self diagnostic feature and can be done by pressing a combination of buttons on the climate control unit. I don't remember exactly what to press as I've read across it years ago. There should be directions on how to do this and how to tell what is the problem somewhere on this forum.
Search up climate control self diagnostic and you should get several results. I have done a quick search and found the thread that I was viewing here but the self diagnostic table is not showing. Here it is: https://acurazine.com/forums/showthr...rol+diagnostic
Here's another which shows you how to do it: https://acurazine.com/forums/showthr...rol+diagnostic
Str8 Home built
