2.5 Transmission filter/screen, pan drop DIY
Old 05-13-2015 | 07:23 PM
  #41
vladungik's Avatar
9th Gear
Thank you for your help! I have acura tl 96 3.2. It was a little bit harder than on photos, but pattern the same 3/8 ratchet is on the passenger side.
Old 09-26-2020 | 05:27 AM
  #42
Skrt Skrt Ern's Avatar
4th Gear
Originally Posted by 5point9Limited
This service is very similar to the KaMLuNg writeup on the 3.2 TL. Part numbers for the 2.5 are on page 2 of his in-depth writeup.
1. Remove plug with a 3/8 inch drive ratchet. Use a small exhaust pipe for extra leverage, as it is on tight!
2. Sludge!! It wasn't as bad as I expected for 110k miles.
3. Loosen the pan bolts with a 10mm socket, easy. I used my cordless impact for this, it is variable speed and it only hammered once for each bolt.
4. I found a great trick to pop the pan loose! Find the flange and over-hang of the pan. Use a screw driver to pry it loose. There is an over-hang on each side. The driver side worked great.
5. Refer to KaMLuNg's post for the filter/screen removal. The 2.5 has 4 bolts of different size, keep track!!
6. Scrape Pan and the bottom of the trans so they are nice and clean and clean the pan very well. I used throttle body cleaner and doused the bottom of the trans. Let it drain and dry out.
7. There are 2 different size bolts for the pan. The longer ones will slide into the hole halfway and then thread. The small will thread right away.
8. Use a funnel and a tube to pour the freshness in.
Notice the difference in color between the new and old from the 1st pic.
9. Refer to KaMLuNg's post for final specs and procedures. I will post back to give a final amount of Trans fluid.
10. Check for leaks.
where is this post for the filter
pistacio
09-26-2015 09:45 AM
Skirmich
09-15-2015 06:41 PM
Allen_442
09-08-2015 06:01 PM
Quick Reply: 2.5 Transmission filter/screen, pan drop DIY
