Preminu VS. Regular?? does it really matter?
Old Sep 6, 2008 | 03:06 PM
N8s1996TL's Avatar
Hey,
I'm thinking about switching from premium to regular gas for my 1996 3.2 TL. For obvious reasons $$$
Does the TL really need the premium??
What do you guys use? What do you think?
Old Sep 6, 2008 | 07:17 PM
KrayzieDxC's Avatar
Khmer Pride
https://acurazine.com/forums/1g-tl-1996-1998-101/go-premium-not-go-premium-proof-685772/
Old Sep 10, 2008 | 12:19 AM
LastBoyScout's Avatar
96 TL 2.5
yeah, im seeing an improvement so far. as of today (filled up sunday) im seeing a 2.5 MPG difference according to my scangauge. I fill up when the Low Fuel Light comes on.
so, if I usually get 14.2xx gallons of gas (my local pumps shows as far as 1000ths of a gallon) and I was getting 26.5 MPG on regular for a total millage of 376.3 miles. If i continue getting 29 MPG for the same 14.2xx gallons then i get a total millage of 411.8 miles. Thats a difference of 35.5 miles.
Now looking at the cost average:
reg: $3.459 * 14.2 gals = $49.1178 or $49.1178 / 376.3 miles = $0.1305/mile (cost per mile)
premium $3.609 * 14.2 gals = $51.2478 or $51.2478 / 411.8 miles = 0.1244/mile (cost per mile)
at a 35.5 mile difference between premium and regular and a cost difference of $0.15 its pretty obvious which one to choose.
But as most people are finding out, gas differs between time of year and region of the US.
We have a known and posted 10% ethanol added to all of our gas, so fuel economy here is not as great as it could be.
Old Sep 10, 2008 | 02:21 PM
5point9Limited's Avatar
I dont think you are checking your mileage correctly. Fill up the tank until the nozzle clicks. Don't top it off. Reset odometer. Drive. Fill it up whenever you want (till the nozzle clicks) and divide the gallons of gas into the miles driven.
The low gas light is not a very accurate way to check, Just my
Old Sep 12, 2008 | 10:10 PM
96 TL 2.5
Im using a scangauge 2 (awesome piece of equipment) and the same pump at the same filling station. I fill up with low flow (the first notch on the pump handle) and i fill it until the pump automatically shuts off.
Then i can either A) use the math equation above which is what I already used B) use what the scangauge reported C) use A and B
Anywho, it gets better mileage.
Believe it or not.
Old Sep 14, 2008 | 03:13 AM
What is scanguage? I will have to try this out for myself/
Old Sep 14, 2008 | 11:08 AM
01tl4tl's Avatar
its a scanner that plugs in and records while you drive- checking all the sensors and settings the engine is using- great for diagnostics
So you can save money up front,,, buying the wrong gas, and put gas in more often-
OR
run the correct grade- get optimal performance and mileage.
which makes more sense??
Honda's are different inside the engine than acura- we need the good gas!!
sell the tl and get a toyota from the 70s if you want great mileage on regular gas
You younger members dont know about 1973 and gas rationing- even/odd plate days of buying gas, 10 gallon limits!, lines around the block....
Old Oct 13, 2008 | 03:39 PM
2.5Inspired's Avatar
OR
In the philippines, they have odd/even plate days of driving.
Old Oct 25, 2008 | 02:22 PM
Mr_Outside's Avatar
Judging on this, should I go ahead and buy a Scangauge II?
Old Oct 26, 2008 | 12:03 PM
01tl4tl's Avatar
spend the 200$ for a scantool,,, on buying the right gas that honda tested and determined the engine requires!
enough people have run scientific test there should be no more questons on the subject
Seafoam the engine too!
Old Nov 3, 2008 | 07:12 PM
Integra_drk's Avatar
pretty sure if the car didnt need premium, honda wouldnt have spent lots of time and money on R&D to determine it does...
baelim
May 10, 2018 09:53 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
