wierd vibration
wierd vibration
I have this problem, when I accelerate heavy the car vibrates prety bad. It doesnt matter if I accelerate from a dead stop or already moving a decent speed. It almost feels like out of balance wheels, but it isnt that because I had them recently balanced and rotated and nothing changed. Also, it is fine as soon as I let out of the gas. the vibration is particularly bad around 55-70mph.
The car has just over 100k miles on it, and as far as I know it has never been in any type of wreck. The CV axles need to be replaced soon, but the boots are not busted.
On another note that might be related, sometimes when I stop there is light annoying vibration at idle when in gear. As soon as I take it out of gear it stops vibrating, but if I hit the gas it is still there. I think that this might be a motor mount, because sometimes it is better than others.
Any idea's? I was thinking that it could be a weak strut or something but they all seem to act fine when cornering and over speed bumps. Harmonic balancer? I don't think that it could be the rotors but maybe? Also, the vibration seems to come mostly from the passenger side of the car.
Ufmwk, I got the same exact problem. I took it to the dealer yesterday for warranty on exhaust & they said my mounts were bad. I asked which one and they said they change both - ("not w/ my money, way too much"). Anyway if the rain lets up today I'm going to try eliminating the vacuum lines solenoid and tap them both into a solid vacuum source. Then disconnect each one individually and see if I get a diff. The other idea I have is way different. But I'm wondering why the new TSX, ect. have solid mounts, not vacuum assist. If I take out the old ones, I'm going to try and machine a new type solid rubber mount. Its easier said than done I know, but $ 260 a pop does not interest me. If it works I'll let every one know. I can get CL mounts for 49 each and they are vacuum, so why aren't ours?
Roark
Roark
Roark
Roark
Where can you get the CL mounts for 49?
MrHeeltoe
20
02-23-2023 01:54 PM
joflewbyu2
10-08-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
