What do all the gears under the D4 do?
Htown slab rider
i was reading online for gas saving tips and they had a place in there which said
Use Overdrive Gears
When you use overdrive gearing, your car's engine speed goes down. This saves gas and reduces engine wear.
and basically i just wanted to know what those are on our cars, ive never really used anything below the d4 before, any info would be appreciated.......detailed information would be Greatly appreciated...thanks ppl.....1
Use Overdrive Gears
You are doing the right thing
Leave it in drive and let it do its thing
Other gears are for accellerating
IF stuck in traffic, drop to 3rd gear, which allows the engine to use all the lower gears and stay out of overdrive, otherwise it will shift back and forth because of low speed
Htown slab rider
whats your take on O2 (oxygen sensors) and gas milage, because gas costs me on an average of $10 each day and on a 5-6day work week i'm getting screwed by the gas station all around my area, someone told me to go on ahead and replace my O2 sensor a while back because its making my ride really sluggish but with gas prices the way they fluctuate i cant really just go buy the O2 sensor because i dont know how much gas is gonna cost me the next week, basically what i'm asking is how much more gas can i save if i go get the O2 sensor, if it can cut my gas consumption in 1/2 then i'm gravy, but if it cant fuck it till i get paid........any help people
my advice is get a second vehicle as a daily driver if u can afford it. I drive my second vehicle during tha wk (burns alot less gas) and the TL on the weekend when im cruising around
If ur gonna get a second vehicle get u something that is in the range of 1.6L - 2.5L. Civic and 4cyl accords are good daily drivers.
大日本帝国
D4: Use all four gears plus overdrive.
D3: Use first three gears.
2: Use only 2nd gear.
1: Use only first gear.
As you can see, 2 isn't the first two, but only the 2nd gear. Your best bet on saving gas is to get different rims. Lighter/narrower with a lower speed rated tyre will help. Lighter for rotating mass, narrower for drag, and not as sticky tire (high treadwear) for less rolling resistance. Obviously there are drawbacks to it, style, etc., but if you're really concerned about mileage, then this is the way to go.
~Cheers~
P.S. The DD thing works, but add up the cost of registration, insurance, etc. and it might end up costing more.
~Cheers~
Originally Posted by longsta
question up to how many miles can u stay in for each gear?
D4: mph max ? or how long
D3: mph max ? or how long
2: mph max ? or how long
1: mph max ? or how long
大日本帝国
All I remember is that D3 is around 99MPH. Once you hit 100, 4th gear engages and response is SHITTY. Our upper-end kinda sucks and our 4th gear REALLY sucks.
~Cheers~
~Cheers~
B A N N E D
the other gears are there for your transmission. D3 stands for destruction 3, d2 stands for destruction 2, d1 stands for destruction 1.. Each is a setting where you can choose on how many days your tranny will last.
Acura added that option when they were watching cartoons while building all of the ua tl transmissions
Have the local parts place pull the codes on your car- it may show an O2 sensor bad or something else
Do the tune up in a can with Seafoam
see gen 2 thread
Seafoamed the Ol TL
amazing stuff- same product is used in the fancy 100 buck machine cleaning at shops
see gen 2 thread
Seafoamed the Ol TL
Htown slab rider
Originally Posted by TL BABY
Teekay,
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
guyvelella
09-30-2015 11:02 PM
AcuraKidd
09-26-2015 04:10 PM
