traction control.
traction control.
what happens if i pull out my TCS on my 3.2?? i dont need it nor want it so if i pull it and the light associated with it will it be just like not having ever had it?? or do other systems use it?
Not sure about the Canadian edition but in the US edition, it was only on the Premium models. As far as removing it, it's tied in with the ABS system's speed sensors, the steering system as well as having some type of lateral acceleration sensor; all of which feed the necessary information to the powertrain control module. Unless you're some sort of automotive engineer, you probably did well to leave it alone. Just make sure it's off when you don't want to use it which is easy since off is the default position.
yeah i decided to just leave it, i thought those systems might be at play and i didnt feel like figuring out what resistors to put where ext....i dont mind the system being there, i just wanted to free up bay space and maybe a cleaner look if i ever put a cold air or similar on there. but for now it stays
mada51589
05-03-2022 08:54 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
Charlespsu
09-02-2015 09:54 AM
