Tire rub
![Angry](https://acurazine.com/forums/images/icons/icon8.gif)
rims: 18 x 7.5 40 offset
tire: 25/40/18
ive already cut out my fender above the notch and put in a set of spacers from autozone. they only rub when i take a sharp turn pretty quick and when i hit a deep bump....particulalrly when i have backseat passengers....is there anything i can do to illeviate this problem..
ps...i did a close inspection to c exactly what is hitting since i dont have inside fenders n e more and i believe it may be the corners of the tab....anyone have n e experience with this or solutions?
tire: 25/40/18
I run 18x9 37 offset with 225/40/18. I rolled my fenders, and trimmed off the edge of the rear bumper, the corners nearest to the tire. Eliminated all rubbing issues I had.
B A N N E D
i cut the whole tab off and used a sheetmetal screw 2 inches further back. this way its not there.. Id bet the noise is coming from the rear bumper almost entirely. Thats where mine was and i have right around the same setup offset and size wise.
The rear bumper bolts onto the fender in the wheel well with a bolt. take that shit out. cut the bumper off there, and just use a screw. Id take a picture but im mega busy.. i think he has it cut. someone could show you with this pic...
B A N N E D
my car is dumped dude. I cant even go over speedbumps(however alot is cause the sideskirt is like 8 inches lower than stock). but even dumped i can ride 4 niggas in the back screamin no limit solider and still not rub.
I think that yes, this should solve yo issues.. if not then we will try the next option once youve done the trimming..
rockvilleTL
09-19-2015 04:44 PM
oyayjoe
09-12-2015 04:40 PM
DunesCreations
09-09-2015 12:03 PM
