Stock rim center caps
Does anybody know if there's a place I can get center caps for the stock wheels? Are center caps pretty specific or are they swappable?
I'm mounting the stockers onto a Toyota Camry that is in need of some wheels (it bent a rim). Having them say ACURA would be kinda sad.
Reppin' the T-Dot!!
1 Post
Not much you can do about that, they are pretty specific to the individual wheel. You could get some bondo from a parts store and fill it in then spray paint it, that would solve the problem rather easily....
Hehe, that's what I was thinking too. But I was hoping it wouldn't come to that.
Actually, your solution is more high tech than my proposal. I was just going to paint and then put a Toyota emblem sticker over it.
TL rims won't fit? Is it the center bore?
Because they're 5 x 114.3
I figured any offset diff won't matter since the wheels are so skinny
Duh: forgot to add they're from a 3.2
2.5 def won't fit because those are 4 lugers. But I thought 5 would for sure.
98 3.2 Flamenco Black
The hub diameter are different, Honda has bigger hubs, so it will not sit well on a toyota hub. Been there, done that.
You want your wheels to ride on your hub, not on the lugs.
Oakes
Wash & Wax
10-12-2015 11:17 AM
