Spark Plugs
Received 2,329 Likes
yeah.. copper ones are a bit cheaper.. in the end I just use platinums since its less fuss.
TL no more!
Originally Posted by wackjum
3.2 comes equipped with platinum plugs. Those are good for 120k miles.
2.5 has copper ones I understand. 30ish is average for those.
Originally Posted by meazz1
Do you need to gap the plugs even if you buy specifically for the right model any year of the car?
How much are these platinum plugs you speak of? And is there any way to check and see if your plugs are new/old is you don't have complete service records?
NGK Platinum XI for $40 shipped via ebay. One of the best investments I have ever made. Had Bosch Plat 4's = sucky. IMO. "ass dyno" told me that the NGK killed the Bosches and upon further research found that the Bosch plugs are designed to run on German cars better. Weird, don't ask... But just run NGK's. You'll be much happier and your car will pull like it hasn't in a long while!
I got a set of Denso Iridiums and replaced at 60K miles. Nice plugs. Bosch are also very good plugs. Both the Denso's and the Bosch come pregapped. Stay away from Splitfires or any other cheap plug. A good buddy of mine put Splitfires into his '99 Mustang, and the tips broke off and fell into the engine...
Registered Abuser of VTEC
I get mine done every 50 000km, with copper plugs. It's cheap and easy to do. I just buy the plugs off the parts centre for the dealer (it's cheap for those), and then I install myself because it's so easy to remove and insert new ones on the 2.5L engine.
acuratl26
04-23-2020 07:30 PM
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
