Seafomed the TL
Tri State ViP Crew
Seafomed the TL
So I dumped half a can into my fuel tank and straight into my engine and ran it, it's running considerably better but can anyone give me detailed descriptions on anywhere else I could dump it and how to go about doing so?
look in gen2 threads for
seafoamed the 'ol TL
Khmer Pride
your everywhere ,01tl4tl. i guest your the only one that helps
you can put it in your break booster if your goin to change your spark plug soon ,pcv ,engine oil before you change ur oil
Didn't you hear the rumor?....I get .00000001 of 1 cent for every can of seafoam sold!!!
Not true sadly
I use the intake manifold vac line rather than the brake booster, it easy to dip and remove
the line from the can that way
The spark plug thing is if you have over 70k miles on the plugs, and you dont do a burnoff cleanout drive after seafoam- you can load the plugs up and it will run bad.
If you have fresh plugs- its never a worry
If you are planning to install NGK Iridiums, then do seafoam and drive 2 days to make sure all is cleared- then replace plugs
Not true sadly
大日本帝国
I'd pour it from the bottle into a small cup (use plastic or glass, not foam) then have the motor suck it from there.
~Cheers~
P.S. 01tl4tl, I Seafoamed after these past 5000+ miles of hard driving and racing, and I STILL have no smoke. I love my motor.
~Cheers~
Look for a 1/4" black rubber flexi vac line coming from the top rear of the engine and running around to the driver side fenderwell where it goes into a fitting and has a matching hose leave that fitting
Use the hose that goes back to the engine
Thats manifold vac line
大日本帝国
Originally Posted by 96teeluxury
Can anyone explain exactly what hose I need to disconnect and where it is on the c25?
~Cheers~
go to gen2 thread list and look for Seafoamed the ol TL, its never far down the page!!
Its a super cleaner for intake and fuel plus it works in the engine oil to clean the passages
great stuff! 6 bucks a pint at any parts store
